Python Toolbox / regular Toolbox -- postExecute not working
3906
9
10-01-2023 09:47 AM
Yanu
Hey guys,
I am dealing with unable to use postExecute method within Python Toolbox or atbx toolbox.
class Tool(object‌‌
    def __init__(self‌‌):
        """Define the tool (tool name is the name of the class)."""
        self.label = "Tool"
        self.description = ""
        self.canRunInBackground = False
    def getParameterInfo(self‌‌):
        """Define parameter definitions"""
        param1 = arcpy.Parameter(
            displayName="Dos",
            name="param1",
            datatype="DEFeatureClass",
            parameterType="Required",
            direction="Input")
        param2 = arcpy.Parameter(
                displayName="Output Features",
                name="out_features",
                datatype="GPFeatureLayer",
                parameterType="Derived",
                direction="Output")
        return [param1, param2]
    def execute(self, parameters, messages‌‌):
        """The source code of the tool."""
        param1 = parameters[0].valueAsText
        gdb  = "gdb_path"
        out =  f"{gdb}/layer2"
        arcpy.CopyFeatures_management(param1, out)
        arcpy.SetParameter(1, out)
        arcpy.AddMessage("Tool has finished executing222")
        return
    def postExecute(self, parameters, messages‌‌):
        """This method takes place after outputs are processed and
        added to the display."""
        arcpy.AddMessage("Tool has finished executing!!!!!!!!!!!!!!!!!!!!")
        try:
            project = arcpy.mp.ArcGISProject('CURRENT')
            active_map = project.activeMap
            if active_map:
                out_layer = active_map.listLayers(os.path.basename(self.params[1].valueAsText))[0]
                symbology = out_layer.symbology
                symbology.updateRenderer('SimpleRenderer')
                symbology.renderer.symbol.applySymbolFromGallery('Airport')
                symbology.renderer.symbol.size = 12
                out_layer.symbology = symbology
        except Exception:
            pass
        return
I've used example from documentation, has anyone had any success with using postExecute?
Do I need to execute it someway?
Code is basic, just for testing purpose.
regards,
Yanu
DanPatterson
MVP Esteemed Contributor
What does the toolbox look like?  That is where you execute the tool from within your project's toolbox
... sort of retired...
Yanu
Toolbox is like this:
import arcpy
import os
class Toolbox(object):
    def __init__(self):
        """Define the toolbox (the name of the toolbox is the name of the
        .pyt file)."""
        self.label = "Toolbox"
        self.alias = "toolbox"
        # List of tool classes associated with this toolbox
        self.tools = [Tool]
Default, postExecute is also from documentation.
They suggested using postExecute:
here Bug with symbology
DanPatterson
Yes that is the code, but have you added the toolbox to your project and tried to execute it?
Catalog, Project tab, Toolboxes with my toolbox which has a tool with a toolset and a tool shown
which you can launch and run to test whether it works or check its properties
for tool validation... (postExecute is commented out here since none is needed)
Yanu
Thank you for your reply Dan.
Yes, I've added this Python Toolbox to project.
I tried also setting up ATBX from scartch and testing if postExecute will run.
Nothing happens...
Luke_Pinner
MVP Regular Contributor
postExecute is new. Are you using ArcGIS Pro 3.x?
Yanu
I know, I am using 3.1.1.
I've checked patch notes, 0 bugs...
DanPatterson
Which leaves the thread you posted BUG-000155515 for ArcGIS Pro (esri.com)
so I would open an Issue with Tech Support so they can investigate why it isn't working.... I don't use postExecute in my toolboxes
FrancescaCella
Hi Yanu, Dan and Luke
I'm using ArcGIS Pro 3.3 and have same problems with "postExecute" routine.
It seems do nothing.
Any news from the BUGS?
DanPatterson
BUG-000155515 for ArcGIS Pro (esri.com)  still lists the status as "known limitation"
so contacting Tech Support would be your best option
