Python Toolbox Question
3952
6
02-22-2021 07:34 AM
ChrisHolmes
Hello,
I have a python toolbox, that has the following tools:
Some of these scripts use the same procedures, so I moved those procedures to the top of the file above all of the individual classes. Which seems to make sense, I don't have exact copies of the same procedure inside each class, fewer lines of code, smaller file...
The top of the file looks like this (this is not all the procedures that are at the top just the first few):
import arcpy
import os
import re
import shutil
import configparser
import subprocess
from time import gmtime, strftime
def OpenAprx(aprx):
    #open the passed in mxd file in a new arcmap instance
    arcpy.AddMessage('Opening: {}'.format(aprx))
    subprocess.Popen([r'C:\Program Files\ArcGIS\Pro\bin\ArcGISPro.exe',aprx])
def CreateImage(prj, mapName, lyrsOn, lyrsOff, lyrExtent, lytName, mapScale, pngFilePath):
    arcpy.AddMessage('CreateImage start {}'.format(strftime("%H:%M:%S", gmtime())))
    arcpy.AddMessage('prj: {}'.format(prj))
    SetLayers(prj, mapName, lyrsOn, 'on')
    arcpy.AddMessage('SetLayers ON completed {}'.format(strftime("%H:%M:%S", gmtime())))
    arcpy.AddMessage('len lyrsOff: {}'.format(len(lyrsOff)))
    if len(lyrsOff) > 0:
        SetLayers(prj, mapName, lyrsOff, 'off')
        arcpy.AddMessage('SetLayers OFF completed {}'.format(strftime("%H:%M:%S", gmtime())))
    ExportImage(prj, mapName, lyrExtent, lytName, mapScale, pngFilePath)
    arcpy.AddMessage('ExportImage completed {}'.format(strftime("%H:%M:%S", gmtime())))
def SetLayers(prj, mapName, lyrs, status):
    arcpy.AddMessage('SetLayers prj = {}'.format(prj))
    aprx = arcpy.mp.ArcGISProject(prj)
    m = aprx.listMaps(mapName)[0]
    for lyr in m.listLayers():
        if lyr.name.upper() in lyrs:
            if status == 'on':
                lyr.visible = True
            else:
                lyr.visible = False
    #aprx.save()
    del aprx
This all seems great to me but the problem is the code executes way slower than when the procedures are all copied in the individual classes. Why is this?
Thanks
by Anonymous User
Not applicable
You could possibly put those functions into a base class, and then use class inheritance for the classes that would use them.
by Anonymous User
Not applicable
I won't pretend that I know how everything gets complied to interpretation but I would think you are essentially creating global functions that have to be compiled/indexed separately than being contained to that a class as a method, so there is some overhead with having to reach out to that function to perform the process.
ChrisHolmes
Ya, that's kind of what I was thinking. Thanks. Still searching around a bit for a proper way of doing this 🙂
by Anonymous User
Not applicable
ChrisHolmes
I think you're on the right track. Here's what I came up with, which is working and is executing in an acceptable amount of time. The actual .pyt file is quite long so I set up an 'example.pyt' which shows how the code
class Toolbox(object):
    import arcpy
    def __init__(self):
        """Define the toolbox (the name of the toolbox is the name of the
        .pyt file)."""
        self.label = ""
        self.alias = ""
        # List of tool classes associated with this toolbox
        self.tools = [SomeTool, AnotherTool,]
    def Procedure1(self, parameter1, parameter2):
        #This is a procedure used by multiple tools in the pyt file.
        #code goes here...
    def Procedure2(self, parameter1):
        #code goes here...
        self.Procedure3('something')
    def Procedure3(self, parameter1):
        #This is a procedure used by Procedure2
        #code goes here...
class SomeTool(object):
    def __init__(self):
        """Define the tool (tool name is the name of the class)."""
        self.label = "Some Tool"
        self.description = " "
        self.canRunInBackground = False
    def getParameterInfo(self):
        """Define parameter definitions"""
        params = None
        return params
    def isLicensed(self):
        """Set whether tool is licensed to execute."""
        return True
    def updateParameters(self, parameters):
        """Modify the values and properties of parameters before internal
        validation is performed.  This method is called whenever a parameter
        has been changed."""
        return
    def updateMessages(self, parameters):
        """Modify the messages created by internal validation for each tool
        parameter.  This method is called after internal validation."""
        return
    def execute(self, parameters, messages):
        """The source code of the tool."""
        def Procedure4(inParameter):
            #This procedure is just for SomeTool
            #code goes here...
        aVariable = Procedure4('blah')
        sT = Toolbox()
        sT.Procedure1(aVariable,'something else')
        sT.Procedure2('something else')
        del sT
        return
class AnotherTool(object):
    def __init__(self):
        self.label = "Another Tool"
        params = None
        return params
        return True
        return
        return
        aT = Toolbox()
        aT.Procedure2('something else')
        del aT
        return
flows.
JohannesLindner
I think Jeff meant something like this:
import arcpy
    def __init__(self):
        .pyt file)."""
        self.label = ""
        self.alias = ""
class BaseTool(object):
    # This class contains all methods that are used by multiple tools in the toolbox.
        #code goes here...
        #code goes here...
        #code goes here...
class SomeTool(BaseTool):  # this class inherits every method from BaseTool
    def __init__(self):
        params = None
        return params
        return True
        return
        return
        # BaseTool contains Procedure1 and Procedure2, and SomeTool inherits them, so you can just call them with self.Procedure1
        aVariable = self.Procedure4('blah')
        self.Procedure1(aVariable,'something else')
        self.Procedure2('something else')
        #code goes here...
class AnotherTool(BaseTool):
    def __init__(self):
        params = None
        return params
        return True
        return
        return
Have a great day!
Johannes
ChrisHolmes
Thanks Johannes. I've adjusted my example file. It's cleaner, executes about the same as before. But makes better sense. Cheers
# -*- coding: utf-8 -*-
    import arcpy
    def __init__(self):
        .pyt file)."""
        self.label = ""
        self.alias = ""
        self.tools = [SomeTool, AnotherTool]
    import arcpy
    def __init__(self):
        .pyt file)."""
        self.label = ""
        self.alias = ""
        #code goes here...
        arcpy.AddMessage('hi from Procedure1. parameter1: {}; parameter2: {}'.format(parameter1,parameter2))
        #code goes here...
        self.Procedure3(parameter1)
        #code goes here...
        arcpy.AddMessage('message from Procedure2: {}'.format(parameter1))
    def __init__(self):
        params = None
        return params
        return True
        return
        return
            return('phrase passed into Procedure4: {}'.format(inParameter))
            #code goes here...
        self.Procedure2('hi there')
        return
    def __init__(self):
        params = None
        return params
        return True
        return
        return
        self.Procedure2('whatever')
        return
