Python Toolbox: Only validate when you press run?
717
09-17-2024 11:58 AM
AlfredBaldenweck
MVP Frequent Contributor
I'm running into an issue where the standard validation is just taking waaaay too long (Describing the input) and I really just need it to validate when I press Run, not beforehand.
That is, if there's an error, only tell me when I press Run.
Has anyone figured out a way to do this?
HaydenWelch
MVP Regular Contributor
You can just rename your validation function so it's not called in the validation loop and run it at the top of your execute function, something like this:
import arcpy
import time
class Tool:
    ... # other methods
    def validateParameters(self, parameters):
        # Expensive validation goes here
        time.sleep(5)
        # Randomly fail validation
        if time.time() % 2 == 0:
            arcpy.AddError("Validation failed")
            return False
        arcpy.AddMessage("Validation complete")
        return True
    def execute(self, parameters, messages):
        # Expensive execution goes here (after run)
        if not self.validateParameters(parameters):
            return
        return
