Python Toolbox:  How to set an output parameter
18528
7
08-21-2012 09:03 AM
MarkCederholm
How do you set an output parameter (e.g. a feature set) in the execute method of a tool in a Python toolbox?  I've tried setting parameters = output and arcpy.SetParameter(n, output) and neither work.  For example, the following script works fine in a regular toolbox:
import arcpy
try:
    arcpy.env.workspace = "in_memory"
    # Get parameters
    Input_Features = arcpy.GetParameterAsText(0)
    Buffers = arcpy.CreateUniqueName("Buffer")
    # Perform buffer
    arcpy.Buffer_analysis(Input_Features, Buffers,
        "100 Feet", "FULL", "ROUND", "NONE", "")
    OutFeatureSet = arcpy.FeatureSet()
    OutFeatureSet.load(Buffers)
    arcpy.SetParameter(1, OutFeatureSet)
except Exception, ErrorDesc:
    sErr = "ERROR:\n" + str(ErrorDesc)
    arcpy.AddError(sErr)
But I can't get the output to work in a Python toolbox:
import arcpy
import os
class Toolbox(object):
    def __init__(self):
        self.label = "Runtime Tools"
        self.alias = ""
        # List of tool classes associated with this toolbox
        self.tools = [BufferTest]
class BufferTest(object):
    def __init__(self):
        self.label = "Buffer Test"
        self.description = "Create buffers"
        self.canRunInBackground = False
    def getParameterInfo(self):
        params = []
        param0 = arcpy.Parameter(
            displayName = "Input Features",
            name = "inputFeatures",
            datatype = "Feature Set",
            parameterType = "Required",
            direction = "Input")
        param0.value = os.path.join(os.path.dirname(__file__),
            "FC_Templates.gdb\PointTemplate")
        params.append(param0)
        param1 = arcpy.Parameter(
            displayName = "Buffers",
            name = "buffers",
            parameterType = "Derived",
            direction = "Output")
        params.append(param1)
        return params
    def execute(self, parameters, messages):
        try:
            # Get parameters
            Input_Features = parameters[0].valueAsText
            # Perform buffer
            # parameters[1] = OutFeatureSet
            messages.addErrorMessage(sErr)
        return
What am I doing wrong?  Thanks!
JustinShepard
Not sure if this would work but a few ideas:
1. try setting your out variable to a parameter (ex. outFeatureClass = parameters[1].valueAsText)
http://resources.arcgis.com/en/help/main/10.1/index.html#/Accessing_parameters_within_a_Python_toolb...
2. This may have nothing to do with it but I don't see where you're setting the parameterDependencies (not sure if it is required for all python toolboxes)
param2.parameterDependencies = [param0.name]
http://resources.arcgis.com/en/help/main/10.1/index.html#/Defining_parameters_in_a_Python_toolbox/00...
MarkCederholm
This works fine if I define param1 as "Feature Class":
        try:
            # Get parameters
            # Perform buffer
            # OutFeatureSet = arcpy.FeatureSet()
            # OutFeatureSet.load(Buffers)
            parameters[1].value = Buffers
        return
Perhaps, unlike a regular toolbox, a Python toolbox cannot understand "Feature Set" as an output type.
KevinBell
Great sample!  I tried adding a distance parameter but it doesn't show up in the dialog when run...  I hope to get my head around these pyt's, but the simple things seem to stump me.
import arcpy
import os
    def __init__(self):
        self.alias = ""
    def __init__(self):
        params = []
        param0.value = r'E:\gis\default.gdb\point'
            displayName = "Buffer Distance",
            name = "distance",
            datatype = "Long",
        param2 = arcpy.Parameter(
            name = "buffers",
        params.append(param2)
        return params
        try:
            arcpy.env.workspace = r'E:\gis\default.gdb'
            Distance = parameters[1].valueAsText
                Distance, "FULL", "ROUND", "NONE", "")
            parameters[2].value = Buffers
        return
KevinBell
It turns out that refreshing the toolbox wasn't working, and closing the mxd and reopening fixed it.  ugh.
AJR
Kevin,
   Thanks for posting this.  I had been getting the same errors when attempting to set the return value in my python toolbox and had been banging my head against the wall until I saw your post.  You are 100% correct, just refreshing the script doesn't work, exiting and restarting the app (ArcCatalog in my case) that the script was built in/called from was required for the extra return parameter to be accessible.  This certainly seems to be a bug, I'm wonder if it's been logged with ESRI?
MarkCederholm
Even at 10.2, Python toolboxes apparently only accept feature sets (GPFeatureRecordSetLayer) as an input parameter; I can't get the data type to work as an output parameter.  I still have to attach a script to a TBX file if I want to create a geoprocessing service or package that outputs a feature set that I build using arcpy.FeatureSet().  Perhaps I should add this issue to the ideas site?
AdamKerz
Mark, I'm not sure, but I think I was having the same problem as you. Defining the output parameter datatype as GPFeatureRecordSetLayer and using SetParameterAsText (I fully tested that function, but with minimal testing, looks like SetParameter also works for me). I'm using 10.2.1.
A basic test case is here:
arcpy - Returning feature class from Python toolbox - Geographic Information Systems Stack Exchange
Hope that stops others from giving up as I almost had.
