Python to concatenate alternating numeric digits from two separate number fields
2020
06-12-2019 11:28 AM
KurtBarclay
I have calc'd the X and Y coordinate value using calc geometry into two separate (numeric / double) fields and now need to combine them into a new string field by alternating the values based upon their individual digit position.
Eample: (note: not using any values after the decimal pt)
Field X_Coor                  Field Y_Coor            New Combined_Field
1831548.520524            490651.99297           8439105645
End result should have text value template of 'X2Y1X3Y2X4Y3X5Y4X6Y5' ... OR 8439105645 (using the example above)
DanPatterson_Retired
def weave(a, b):
    """mini-weave"""
    a = str(a).split(".")[0][1:]
    b = str(b).split(".")[0][:-1]
    return "".join([*sum(zip(a, b), ())])
weave(1831548.520524, 490651.99297)
'8439105645'
'weaving' two sequences with conditions.  This is a mini-version of a much larger problem.
Line 3... skip the first number in sequence 'a'
Line 4... skip the last number in sequence 'b'
Line 5... the magic
For a field calculator expression, line 8 would be
weave(!a_field!, !b_field!)
Any further deviations from your example entail greater condition checking and hence a much longer version
PS, I should add you can 'int' or 'float' the string output if you don't need it in string format
KurtBarclay
Thanks Dan,
I loaded your script into the Field Calc w/Prelogic and am receiving errors.
I'm working thru it, but if you have an suggestions ... I'll take them.
I really appreciate your help
ArcGIS Pro? hence, Python 3?
I would have to see the screen grab of the code block section in the field calculator (which it is initially designed for).
So add a new field, select calculate field, copy and paste the code from a text editor (like notepad or notepad++) into the code block.
It says there is a syntax error in line 5... I am trying to rule out things like format issues, wrong line terminators etc.  So run a check on the syntax.
the starred expression in line 5... can't remember if it was just a python 3 thing,
