Python syntax error
1115
10-07-2013 12:13 PM
ChrisBlankenship
I am getting a syntax error using PyScripter on this line of code:
arcpy.env.tooldataWorkspace=(C:/Temp:cab_homework_3_solution/Tooldata"")
Anyone know why?
MathewCoyle
Honored Contributor
First of all, tooldataWorkspace is not a thing. Second, you need quotes around paths. Third, your path is mangled, there should be no colons after the drive letter.
I assume you are looking for something like this.
arcpy.env.workspace = ("C:/Temp/cab_homework_3_solution/Tooldata")
