python syntax error
2072
12-13-2016 11:50 AM
MatthewUpchurch1
I'm having a bit of trouble figuring out what is wrong with this script. I am trying to tell it "if there is a direction in the pdir/sdir field, concatenate the string into the field, otherwise just print the sname + typ". It says the syntax error is on line 3. Thanks.
def reclass(pdir,sdir,typ,sname):
    if (pdir == 'N'):
        return pdir + ' ' + sname + ' ' typ
    elif (pdir == 'S'):
    elif (pdir == 'E'):
    elif (pdir == 'W'):
    elif (sdir == 'N'):
        return sname + ' ' typ + ' ' + sdir
    elif (sdir == 'S'):
    elif (sdir == 'E'):
    elif (sdir == 'W'):
    else:
        return sname + ' ' + typ
DanPatterson_Retired
you are missing a + before typ  and if typ is numeric it should be str(typ)
better
"{} {} {}".format(pdir, sname, typ)
better
MatthewUpchurch1
Thanks Dan Patterson! Amateur mistake lol. How would I use the .format() in the field calculator though?
just replace all your
return ... your lines where you will forget the plus or space    ..... with
return  ...my line
return  .... modify my line 1 to reflect your new order for N, S, E and W it
ie sname, typ, sdir
my format line replaces the { } with the contents of the values in the format side. since they are in order they will fill those brackets with the values... Note, that I put a space inbetween them... you could use commas or whatever in between them.  The trick is  the values are converted to strings automatically so there is no need for str ing anything.  and it will return a string as output
