Python software to go with ArcGIS ?
5323
13
02-27-2017 09:01 AM
DEAF_PROBERT_68
Honored Contributor
I do have a question and not sure how do I say this but I recalled two years ago that I did had Pyscripter to write code that go with ArcGIS python. This is much easier than doing it in ArcGIS python window. What do you call that ?  AND what kind of software do you recommend me to use to go with it ?
Two years ago I used Pyscripter to work with codes and it was very helpful. Now, it has been two years since I last used and wanted to know if there are one that is much improved or recommend or should I stay with Psycripter ?
Thank you,
NeilAyres
Pyscripter is up to date. Does everything I need it to do.
PyScripter download | SourceForge.net
DanPatterson_Retired
Curtis, the actual zips and the latest are still dated 2015... check, it is the same one I have
DEAF_PROBERT_68
Honored Contributor
Thank you everyone ! I really appreciate your help and it make sense !
DEAF_PROBERT_68
Honored Contributor
I will stick with Pyscripter for now, since I am still using 10.3.1 here at my work.
