Python Sequential Number Gen starting value
2029
04-11-2011 11:01 AM
GabeMarcello
Looking for a way to adapt this Python sequential number generator to use the LAST value +1 in a given field for pStart:
rec=0
def autoIncrement():
global rec
pStart = 1 #adjust start value, if req'd
pInterval = 1 #adjust interval value, if req'd
if (rec == 0):
  rec = pStart
else:
  rec = rec + pInterval
return rec
autoIncrement()
DarrenWiens2
MVP Alum
There's probably a one-liner function out there that tells you the last number in a list of numbers, but this works:
import arcpy
input = "H:/GIS_Data/TEMP_GDB.gdb/feattoline" # your feature class
field = "OBJECTID A" # the name of the field, sorted ascending
rows = arcpy.SearchCursor(input,"","","",field)
for row in rows:
    number = row.OBJECTID
This code simply sorts the values in the field "OBJECTID," assigns and overwrites that value to the variable "number" for each increasing value. Finally, you're left with the largest value of "OBJECTID." Then, make pStart = number.
GabeMarcello
import arcpy
for row in rows:
This worked exactly how I wanted it to. Thank you. You truly are the wind beneath my wings.
