Python select_analysis where clause for numeric field
5350
10
10-18-2016 03:52 PM
PitersonPaulgek
I get error "Invalid expression" for:
where_clause ='"Yr" IS NULL'
arcpy.Select_analysis(InFC, OutFC, where_clause)
What is the correct syntax?
PitersonPaulgek
Fortunatelly, I run the simple test (Delete and Select) - it worked in ModelBuilder and then exported to PythonScript with syntax :
arcpy.Select_analysis(in_features,out_features, "Yr IS NOT NULL")
Thanks for help!!!
