Python Scrypt to step back a directory
46213
09-14-2011 02:08 PM
philiptivel
I would like to step back a directory in python without having to prompt the user to do it in my script. For example the user selects a dataset here C:\Projects\test\database.mdb\dataset to run a process on. I then want the database that the dataset is in to be compacted without prompting the user for the database as well. Basically I want to know what the python version of cd.. is
MarcNakleh
Hi there,
There are a couple of ways to do this, though Python's built-in way would be:
os.path.dirname(path_to_dataset)
import os
pathX = r'C:/Hello/HelloWorld'
print os.path.dirname(pathX)
Result: C:/Hello
which returns the parent directory of the file or folder under consideration. So, if you feed it a file, it will give the directory the file is in. If you give it a folder, it will return the folder hosting it.
philiptivel
That worked great, thanks!
RDHarles
You can also do what you were suggesting in your original post (change directories "back one") by using os.chdir():
import os
print "Current: "+os.getcwd()
>> C:/jobs/Alpine
os.chdir('..')
print "Back one dir: "+os.getcwd()
>> C:/jobs
