Python script with user input options not working in geoprocessing service
2837
7
02-24-2021 04:40 AM
JayakumarPD
Hi,  we are using arcgis 10.4 and server also same.
We have created a arcpy script with From_date, To_date options with additional two parameters for user to enter.  In local machine and in server machine it is running, when we run in arcpy window.
But when it is published as service, it is taking time and with out any error it publishes.
when we run it with parameter, it shows message submitted...executing then it fails, giving the error ESRI type error, with out any time lag.
Is it possible to debug this gp service while running, how to put the checks to know where I am failing.
Kindly suggest.
jcarlson
How exactly are the inputs being implemented? In the script itself with input()? Or are you using the script input options from w/in the program?
- Josh Carlson
Kendall County GIS
JayakumarPD
hi Jcarlson,
please find the attached code and kindly suggest.
DavidPike
MVP Notable Contributor
Same as jcarlson is saying, also give more info, your code, your parameters etc.
Check the arcgis server log, query->debug etc.
JayakumarPD
hi DavidPike,
JayakumarPD
This is the code for reference
import arcpy
import os
import arcgisscripting
gp = arcgisscripting.create()
arcpy.env.workspace = "C:\\Users\\saslam\\AppData\\Roaming\\ESRI\\Desktop10.4\\ArcCatalog"
myDB = "Database Connections\\alias_name__server_ip_adress.sde" # sde file for database connection
sqlConn = arcpy.ArcSDESQLExecute(myDB)
# fetching parameters from gui
rangecode_param = ''
stdate_param = ''
eddate_param = ''
sectioncode_param = ''
beatcode_param = ''
tid_param = ''
forest_code_param = ''
try:
rangecode_param = arcpy.GetParameterAsText(0)
stdate_param = arcpy.GetParameterAsText(1)
eddate_param = arcpy.GetParameterAsText(2)
sectioncode_param = arcpy.GetParameterAsText(3)
beatcode_param = arcpy.GetParameterAsText(4)
tid_param = arcpy.GetParameterAsText(5)
forest_code_param = arcpy.GetParameterAsText(6)
except Exception as e:
print(e)
feature_info = []
tripid = ''
features = []
feat = []
count = 0
try:
query1 = "some sql query for mandatory inputs"
ifelse condition lader for optional user inputs
if sectioncode_param != '':
query1 = query1 + "and sectionCode = '"+sectioncode_param+"'"
elif beatcode_param != '':
query1 = query1 + "and beatCode = '" + beatparam + "'"
elif tid_param != '':
query1 = query1 + "and tripId = '" + tid_param + "'"
TripData = sqlConn.execute(query1)
result = TripData
tid = []
for p in result:
feature_info.append([str(p[1]), str(p[0])])
tripid = p[2]
# tid.append(str(p[2]))
features = []
for i in feature_info:
ix = float(i[0])
iy = float(i[1])
feat.append((ix, iy))
fc = "E:\\sadiq\\live proj\\working\\New Personal Geodatabase.mdb\\pat_point"
cursor = arcpy.da.InsertCursor(fc, ["SHAPE@XY", "tripid"])
for row in feat:
cursor.insertRow([row, tripid])
arcpy.env.workspace = "E:\\sadiq\\live proj\\working\\New Personal Geodatabase.mdb"
Buff = "E:\\sadiq\\live proj\\working\\New Personal Geodatabase.mdb\\new_buff_v7"
arcpy.Buffer_analysis("E:\\sadiq\\live proj\\working\\New Personal Geodatabase.mdb\\pat_point", Buff, "50 Meters", "FULL", "ROUND", "LIST", "tripid")
if forest_code_param != '':
inputfc = "Database Connections\\*******database server*******\\********database table********"
gp.Select_analysis(inputfc, "E:\\sadiq\\live proj\\working\\New Personal Geodatabase.mdb\\featureclass", "ForestCode = '"+forest_code_param+"'")
inFeatures = ["E:\\sadiq\\live proj\\working\\New Personal Geodatabase.mdb\\new_buff_v7", "E:\\sadiq\\live proj\\working\\New Personal Geodatabase.mdb\\featureclass"]
else:
inFeatures = ["E:\\sadiq\\live proj\\working\\New Personal Geodatabase.mdb\\new_buff_v7", "Database Connections\\*******database server*******\\********database table********"]
outFeatures = "E:\\sadiq\\live proj\\working\\New Personal Geodatabase.mdb\\intersect_7"
arcpy.Intersect_analysis(inFeatures, outFeatures, "")
arcpy.DeleteRows_management("E:\\sadiq\\live proj\\working\\New Personal Geodatabase.mdb\\pat_point")
print(e)
 below are some snap shots that were captured while running the script as a geoprocessing service
Capture1.PNGCapture1.PNGCapture2.PNGCapture2.PNGwhen clicked on "Check Job Details Again" displays this without even a second timelapse.when clicked on "Check Job Details Again" displays this without even a second timelapse.Capture4.PNGCapture4.PNG
kindly help resolving this
Thanks in advance
DavidPike
I'll have a look through, but in the meantime you may get some better logging info by republishing (or maybe you can change in server manager?) and setting the logging to verbose or something (I cant quite remember where the option is, but there is one) this might capture a better log next time it fails.
by Anonymous User
Not applicable
So, I see where you are getting the dates, but I do not see you use them anywhere in your code.  Are you using them in your sql query? Have you tried with a default value from the script and not from the geoprocessing service input?
# sets a default if the parameter comes back empty or None
if stdate_param == '#' or not stdate_param:
    stdate_param = '2020-05-01'
 and here, you are concatenating the strings together
 will make your query1 end up like:
"some sql query for mandatory inputs and sectionCode = '"+sectioncode_param+"'"
Unless you took it out to post on the forum since you mentioned that it works as a script...
Last thing I can think of as is, can the server you have this process on use the myDB connection (username/password, SSO, etc)- i.e., its not tied to your login so it only works when you are logged in?
