Python Script to Auto update Web Map from Arc Pro project
352
06-23-2026 01:10 PM
MatthewAllen
I would like to create a python Script to automatically update my web map from my ArcPro project.
I have a ArcPro project that I manually update the web map right now.
I also used experience builder to create a user-friendly web map that uses the data from my published web map.
I have attached my first try at a script, but it doesn't work. Any help on how to fix the script would be appreciated.
TonyAlmeida
MVP Regular Contributor
1st Script: Double check you are signed in and correct portal connection
arcpy.server.UploadServiceDefinition(sd, portal_url)
print(arcpy.GetActivePortalURL())
Change raise Exception(f"Map '{map_name}' not found.")
to
sddraft = os.path.join(sharing_draft_folder, f"{service_name}.sddraft")
sd = os.path.join(sharing_draft_folder, f"{service_name}.sd")
print(f"{service_name} published successfully!")
And for the Exception try,
except Exception:
print("Publishing failed.")
print(arcpy.GetMessages(0))
print(arcpy.GetMessages(1))
print(arcpy.GetMessages(2))
raise
2nd script:
You are missing your drive letter, PROJECT = r"\GISdata\ArcGISPro_Projects\SamplePublishArcPly.aprx", something like, PROJECT = r"C:\GISdata\ArcGISPro_Projects\SamplePublishArcPly.aprx"
before C:\GIS\Logs, add
os.makedirs(r"C:\GIS\Logs", exist_ok=True)
os.makedirs(OUTPUT_FOLDER, exist_ok=True)
Error Handling try
try:
except Exception as ex:
logging.error(ex)
logging.error(arcpy.GetMessages())
raise
import arcpy
import os
aprx_path = r"C:\GISdata\ArcGISPro_Projects\SamplePublishArcPly.aprx"
map_name = "SampleAutoPublish"
service_name = "SampleAutoPublish"
portal_url = "https://www.arcgis.com"
username = "xyzx"
password = "yyyy"
sharing_draft_folder = r"C:\GIS\Publishing"
description = "Sample Auto Publish Feature Layer"
tags = "GIS, Caldwell County, Sample"
arcpy.SignInToPortal(portal_url, username, password)
aprx = arcpy.mp.ArcGISProject(aprx_path)
maps = aprx.listMaps(map_name)
if not maps:
map_obj = maps[0]
sharing_draft = map_obj.getWebLayerSharingDraft(
    "HOSTING_SERVER",
    "FEATURE",
    service_name
sharing_draft.summary = description
sharing_draft.description = description
sharing_draft.tags = tags
sharing_draft.overwriteExistingService = True
os.makedirs(sharing_draft_folder, exist_ok=True)
sd = os.path.join(
try:
    print("Creating SDDraft...")
    sharing_draft.exportToSDDraft(sddraft)
    print("Staging service...")
    arcpy.server.StageService(sddraft, sd)
    print("Uploading service...")
        sd,
        "HOSTING_SERVER"
except Exception:
    raise
2nd script:
Also, Double check you are signed in and correct portal connection
 arcpy.server.UploadServiceDefinition(sd, PORTAL)
import arcpy
import os
import datetime
import logging
MAP_NAME = "SampleAutoPublish"
SERVICE_NAME = "SampleAutoPublish"
OUTPUT_FOLDER = r"C:\GIS\Publishing"
LOG_FOLDER = r"C:\GIS\Logs"
PORTAL = "https://www.arcgis.com"
USERNAME = "your_username"
PASSWORD = "your_password"
os.makedirs(LOG_FOLDER, exist_ok=True)
logging.basicConfig(
    filename=os.path.join(LOG_FOLDER, "Publish.log"),
    level=logging.INFO,
    format="%(asctime)s %(levelname)s %(message)s"
try:
    arcpy.SignInToPortal(PORTAL, USERNAME, PASSWORD)
    aprx = arcpy.mp.ArcGISProject(PROJECT)
    maps = aprx.listMaps(MAP_NAME)
    if not maps:
        raise Exception(f"Map '{MAP_NAME}' not found.")
    m = maps[0]
    sharing_draft = m.getWebLayerSharingDraft(
        "HOSTING_SERVER",
        "FEATURE",
        SERVICE_NAME
    sddraft = os.path.join(OUTPUT_FOLDER, f"{SERVICE_NAME}.sddraft")
    sd = os.path.join(OUTPUT_FOLDER, f"{SERVICE_NAME}.sd")
    for f in [sddraft, sd]:
        if os.path.exists(f):
            os.remove(f)
        sd,
        "HOSTING_SERVER"
    logging.info(f"{SERVICE_NAME} successfully overwritten.")
    print(f"Completed: {datetime.datetime.now()}")
    logging.error(str(ex))
    print("Publish failed.")
    print(ex)
    print(arcpy.GetMessages())
