PYthon Script No Longer Works Correctly
591
05-29-2013 11:50 AM
TerryHiggins1
New Contributor III
First let me state that I am not very experienced with Python. I had captured a script from ESRI that I think I might have tweaked. However the script worked fine to produce output in a text file. Now when I run it whether intereactive or from a script all I get is a listing of the MXDs within the interactive window and in the text file I basically get the header information and nothing more. The last time I ran this was in August last year.
Can someone assist me in identifing what I am doing wrong or what might have changed?
Note I am running 10.1 on Win7
Thanks in advance
Terry
ThaiTruong
Occasional Contributor II
You also need to modify:
#Read input parameters from GP dialog
    folderPath = arcpy.GetParameterAsText(0)
to:
    folderPath = parentDir
Also, making sure there's a "PyTest" folder under your C drive for this to work.
TerryHiggins1
New Contributor III
Thanks I got it to work. I would like to enhance this script to do some additional things but not sure how to approach. Any chance you could assist on this and point me in the right direction?
1.) Locate a particular FC within the MXD and it's data source
Example - we receive an updated shapefile from the county and want to verify all MXD data sources are pointing to the correct file. I am trying to get all MXDs to use the same geodatabase.
2.) Only report on MXDs that have broken data sources
JimCousins
MVP Regular Contributor
You need to look at the following link:
http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#//00s500000020000000
towards the bottom is a section "Using the arcpy.mapping module to find and repair data links for a number of map documents"
Regards,
Jim
