Python Script Help - Spaces in filename
11079
7
05-23-2012 04:13 AM
JamesMitchell
Hello,
Please can somebody provide some advice?
I am using the code below in a script to add a field to multiple shapefiles, however when the filename or file location contains spaces it does not work. I get the error  message "Input Table: xxxxx does not exist or is not supported"
I think it must have something to do with the LayersList = string.split(arcpy.GetParameterAsText(0),";") line, but as i am new to Python i do not know how to correct it.
It will be greatly appreciated if someone can help me.
Thank you.
James
import arcpy, os, string
#Read input parameters from script tool
# Process: Add Field
for Layer in LayersList:
arcpy.AddField_management(Layer, "DUP", "DOUBLE", 9, "", "", "Dup", "NULLABLE")
Luke_Pinner
MVP Regular Contributor
It's because arcpy is wrapping single quotes around the file path.
print repr(Layer) >>> u"'C:\\WorkSpace\\test workspace\\test.shp'"
This works:
import arcpy, os  #Read input parameters from script tool LayersList = arcpy.GetParameterAsText(0).split(";")  # Process: Add Field for Layer in LayersList:     arcpy.AddMessage(repr(Layer))     arcpy.AddField_management(Layer.strip("'"), "DUP", "DOUBLE", 9, "", "", "Dup", "NULLABLE")
JamesMitchell
Thank you ver much for the quick response.
I have tried this and it still has the same error.
The input parameters are shapefiles.
Thanks
MathewCoyle
Honored Contributor
You should remove any spaces from your shapefile names.
JamesMitchell
Thank you,
The shapefiles are in different locations. When i save them into a folders without any spaces it works but when i move them into a folder location with spaces it no longer works.
Thanks for your input.
MathewCoyle
Honored Contributor
Spaces in path names are not supported either for some functions.
Luke_Pinner
This works:
JamesMitchell
Hello,
Yes, that has corrected the issue. Thank you very much for the help.
James
MaryM
Thank you, this helped me figure out how to remove the extra quotes from my layer files that had spaces.
http://forums.arcgis.com/threads/94529-Layer-Invalid-Data-Source
