python script - forloop tiger files
4530
10-09-2014 11:13 AM
Naga_RaghuveerModala
Can anyone help with the following python code. I am reading TIGER Files 1992 with .F5 extensions into the Quick import tool using python
# import system modules import arcpy from arcpy import env import os   arcpy.CheckOutExtension("DataInteroperability")   env.workspace = "C:/Users/raghuravi/Desktop/GabeWork/TIGER1992" feature_classes = [] for dirname, dirnames, filenames in os.walk("C:/Users/raghuravi/Desktop/GabeWork/TIGER1992"):     for subdirname in dirnames:         print os.path.join(dirname, subdirname)         env.workspace = os.path.join(dirname, subdirname)         fcList = arcpy.ListFiles()         for fc in fcList:             out_name = arcpy.Describe(fc).baseName + "_polygon"             arcpy.QuickImport_interop("""TIGER,fc,"RUNTIME_MACROS,""LFIELD_AS_STRING,YES,TIGER_EXPOSE_FORMAT_ATTRS,,USE_SEARCH_ENVELOPE,NO,SEARCH_ENVELOPE_MINX,0,SEARCH_ENVELOPE_MINY,0,SEARCH_ENVELOPE_MAXX,0,SEARCH_ENVELOPE_MAXY,0,CLIP_TO_ENVELOPE,NO,_MERGE_SCHEMAS,YES"",META_MACROS,""SourceLFIELD_AS_STRING,YES,SourceTIGER_EXPOSE_FORMAT_ATTRS,,SourceUSE_SEARCH_ENVELOPE,NO,SourceSEARCH_ENVELOPE_MINX,0,SourceSEARCH_ENVELOPE_MINY,0,SourceSEARCH_ENVELOPE_MAXX,0,SourceSEARCH_ENVELOPE_MAXY,0,SourceCLIP_TO_ENVELOPE,NO"",METAFILE,TIGER,COORDSYS,,IDLIST,,__FME_DATASET_IS_SOURCE__,true"""",out_name.gdb")
I am getting the following error:
ExecuteError: fc is neither a file or directory, Tiger access failed.
Could not open TIGER/Line dataset
Tool execution failed.
Failed to execute (QuickImport)
XanderBakker
Esri Esteemed Contributor
Not sure if you are still looking for an answer to this question.
If you manually import single file with Interop, does that work? If so, copy the Python snippet of the tool from the Result window and compare the parameters to what you are using in your script. I see a lot of quotes and part of the parameters are commented out in your code.
import arcpy
import os
        for fc in fcList:
