Python Script failing at Copy / Append / Insert step
1314
6
04-20-2026 02:01 PM
Sean_Gambrel
Hello,  The script below joins a table to a feature class and then copies specific features from there into a different, existing feature class.  This has run smoothly for over a year, but recently there was a change in the database that the table comes from, and now the script fails at the append step.  Nothing has changed on the gis-side - feature classes, locations, etc.  We've been tinkering with this for months now and are not getting any closer to a solution.
The traceback we're getting has it specifically failing on the 'with arcpy.da.SearchCursor(...' line (Line 359 ).  It doesn't make it to the for loop or .getMessages()
 This has been tinkered with a lot since the last time it was successfully ruin.  First we were told to not do a copy feature / paste feature (how it came out of Model Builder), but ratehr an insert.  Then there was a question of whether or not an edit session was needed.  Then we were suggested using an insert cursor...  I built the original in Modelbuilder and exported to Python, which is about the extent of my skills.  A colleague who is skilled in Python but new to GIS has been doing most of the work now.  Any idea what might be going on?  Really appreciate your help !
# Name:        SurveyPlatAutomation
# Purpose:  This script identifies surveys marked complete in Accela and grabs
#           selected information for each from Accela.  The parcel ID from
#           Accela is used to select a parcel, copy its geometry to the Survey
#           Plat layer in editgis, and populate the attribute table with the
#           Accela field information.
# Author:      [email protected]
# Created:     01/21/2025
# Updated:     01/21/2026 - sent from Sean
#              01/28/2026 - updated connection string/query for new server
#              02/09/2026 - fixed sql query, tried arcpy Editor class
#              02/17/2026 - Editor crashed at start of run, trying InsertCursor
#              03/04/2026 - format dataframe to match feature class exactly
#              04/06/2026 - check for datum errors
#              04/16/2026 - strip csv table prefix from table before insert
from datetime import date
import os
import shutil
import sys
import time
import arcpy
import pandas as pd
import pyodbc
import smtplib
from email.mime.multipart import MIMEMultipart
from email.mime.text import MIMEText
# new server
connection_string = (
    REMOVED
query = """
SELECT *
FROM OPENQUERY([BOCO-ASYNC-PROD-DB.US.ERDB.ACCELA.COM,14332], '
SELECT V_RECORD.RECORD_ID AS survey_id
 ,V_RECORD.RECORD_TYPE AS docket_type
 ,V_RECORD.DATE_OPENED AS app_date
 ,V_RECORD.SHORT_NOTES AS document_title
 ,V_RECORD.[DESCRIPTION] AS description
 ,V_PARCEL.PARCEL_NBR AS parcel_id
 ,V_RECORD.ADDR_FULL_LINE# AS address
FROM V_RECORD
JOIN V_PARCEL ON V_RECORD.RECORD_ID = V_PARCEL.RECORD_ID
WHERE V_RECORD.DATE_OPENED >= ''2025-01-01''
 AND V_RECORD.RECORD_TYPE = ''Land Survey Plat''
 AND V_RECORD.[STATUS] = ''Accepted Completed''
def main():
    start_time = time.time()
    today = date.today()
    formatted_date = today.strftime('%m/%d/%Y')
    # os.system('pause')
    surveys = query_accela(
        connection_string,
        query
    split_surveys = return_by_parcel_id(surveys)
    # get lists from returned dictionary
    process_surveys = split_surveys['surveys']
    missing_surveys = split_surveys['missing_id']
    multi_surveys = split_surveys['multi_id']
    # create list of features to upsert
    feature_class_update = []
    # lists of records containing nonetype values
    surveys_with_null_values = []
    # iterate through process_surveys
    for survey in process_surveys:
        # check for null values
        if survey['survey_id'] is None:
            surveys_with_null_values.append(survey)
        elif survey['docket_type'] is None:
        elif survey['app_date'] is None:
        elif survey['document_title'] is None:
        elif survey['description'] is None:
        else:
            # dictionary for each feature
            feature_attributes = {}
            # set survey_id
            feature_attributes['survey_id'] = survey['survey_id']
            # set parcel_id
            feature_attributes['parcel_id'] = survey['parcel_id']
            # set survey_type
            if survey['document_title'].startswith('IMPROVEMENT'):
                feature_attributes['survey_type'] = 'Improvement Survey Plat'
            elif survey['document_title'].startswith('ALTA'):
                feature_attributes['survey_type'] = 'Land Survey Plat'
            elif survey['document_title'].startswith('LAND'):
            else:
                feature_attributes['survey_type'] = 'Other Type of Plat'
            # set survey_descr
            raw_description = survey['description']
            # section
            if 'SECTION ' in raw_description:
                sec_abbr = raw_description.replace('SECTION ', 'SEC')
            elif 'SEC. ' in raw_description:
                sec_abbr = raw_description.replace('SEC. ', 'SEC')
            elif 'SEC ' in raw_description:
                sec_abbr = raw_description.replace('SEC ', 'SEC')
            else:
                pass
            # abbreviate township
            if 'TOWNSHIP ' in sec_abbr:
                town_abbr = sec_abbr.replace('TOWNSHIP ', 'T')
            else:
                pass
            # abbreviate range
            if 'RANGE ' in town_abbr:
                range_abbr = town_abbr.replace('RANGE ', 'R')
            else:
                pass
            # abbreviate quarter
            if 'QUARTER' in range_abbr:
                quarter_abbr = range_abbr.replace('QUARTER', '1/4')
            else:
                pass
            # abbreviate northeast
            if 'NORTHEAST' in quarter_abbr:
                ne_abbr = quarter_abbr.replace('NORTHEAST', 'NE')
            else:
                pass
            # abbreviate southeast
            if 'SOUTHEAST' in ne_abbr:
                se_abbr = ne_abbr.replace('SOUTHEAST', 'SE')
            else:
                se_abbr = ne_abbr
                pass
            # abbreviate southwest
            if 'SOUTHWEST' in se_abbr:
                sw_abbr = se_abbr.replace('SOUTHWEST', 'SW')
            else:
                sw_abbr = se_abbr
                pass
            # abbreviate northwest
            if 'NORTHWEST' in sw_abbr:
                nw_abbr = sw_abbr.replace('NORTHWEST', 'NW')
            else:
                nw_abbr = sw_abbr
                pass
            # abbreviate north
            if 'NORTH' in nw_abbr:
                n_abbr = nw_abbr.replace('NORTH', 'N')
            else:
                n_abbr = nw_abbr
                pass
            # abbreviate east
            if 'EAST' in n_abbr:
                e_abbr = n_abbr.replace('EAST', 'E')
            else:
                e_abbr = n_abbr
                pass
            # abbreviate south
            if 'SOUTH' in e_abbr:
                s_abbr = e_abbr.replace('SOUTH', 'S')
            else:
                s_abbr = e_abbr
                pass
            # abbreviate west
            if 'WEST' in s_abbr:
                w_abbr = s_abbr.replace('WEST', 'W')
            else:
                w_abbr = s_abbr
                pass
            # concat document_title and abbr_description
            abbr_description = w_abbr
            final_description = survey['document_title'] + ', ' + abbr_description
            # check for 255 chars
            if len(final_description) <= 254:
                feature_attributes['survey_descr'] = final_description
            else:
                feature_attributes['survey_descr'] = final_description[:254]
            # set survey_year
                feature_attributes['survey_year'] = '0000' # check with Sean...
            else:
                feature_attributes['survey_year'] = str(survey['app_date'].year)
            # set PLSS_COORD, it will always equal 'N'
            feature_attributes['PLSS_COORD'] = 'N'
            # set survey_link
            path = r'V:\ScannedMaps\SURVEY\LANDSURVEY''\\'
            year_last_2 = feature_attributes['survey_year'][-2:]
            survey_id_last_4 = feature_attributes['survey_id'][-4:]
            suffix = '-01'
            file_ext = '.pdf'
            filename = year_last_2 + survey_id_last_4 + suffix + file_ext
            feature_attributes['link'] = path + filename
            # add to feature_class_update
            feature_class_update.append(feature_attributes)
    # accela data as a dataframe
    df = pd.DataFrame(feature_class_update)
    clean_df = rename_reorder_df(
        df,
        rename_map={
        'survey_id': 'SURVEY_ID',
        'survey_type': 'SURVEY_TYP',
        'survey_descr': 'SURVEY_DES',
        'survey_year': 'SURVEY_YR',
        'PLSS_COORD': 'PLSS_COORD',
        'link': 'LINK',
        'parcel_id': 'PARCEL_NO'
        column_order=[
            'SURVEY_ID', 'SURVEY_TYP', 'SURVEY_DES', 'SURVEY_YR', 'PLSS_COORD',
            'LINK', 'PARCEL_NO'
    # the gis
    print('GIS functions:')
    # environment settings
    arcpy.env.overwriteOutput = True
    # cleanup from previous session
    print('Deleting old SurveysAdded...')
    surveys_added = r'V:\\prjlu\\SurveyPlats\\PlatProcessingAutomation\\SurveyProcessing.gdb\\SurveysAdded'
    arcpy.management.Delete(
        in_data=[surveys_added]
    )[0]
    print('Saving Accela df as csv...')
    # saving df as csv
    accela_table = r'V:\\prjlu\\SurveyPlats\\PlatProcessingAutomation\\TableFromAccela.csv'
    clean_df.to_csv(accela_table, index=False)
    # csv to table
    csv_table = 'csv_table'
    workspace = r'V:\\prjlu\\SurveyPlats\\PlatProcessingAutomation\\SurveyProcessing.gdb'
    table_output = arcpy.conversion.TableToTable(
        accela_table,
        workspace,
        csv_table
    # create table view
    print('Creating table view...')
    table_view = 'csv_table_view'
    arcpy.management.MakeTableView(
        table_output,
        table_view
    # temporary feature layer from feature class
    print('Creating temporary layer from Parcels feature class...')
    parcels = r'V:\\gislu\\_DatabaseConnection\\regis1.boco.gis.dc.sde\\boco.PARCELS.PARCELS'
    parcels_layer = 'parcels_layer'
    arcpy.management.MakeFeatureLayer(parcels, parcels_layer)
    # join
    print('Joining csv table view to Parcels feature class...')
    arcpy.management.AddJoin(
        in_layer_or_view=parcels_layer,
        in_field='PARCEL_NO',
        join_table=table_view,
        join_field='PARCEL_NO',
        join_type='KEEP_COMMON'
    # export features
    print('Exporting table to SurveysAdded feature class...')
    arcpy.management.CopyFeatures(
        parcels_layer,
        surveys_added
    # remove join
    print('Removing temporary join...')
    arcpy.management.RemoveJoin(parcels_layer)
    # strip 'csv_table_' prefix from surveys_added fieldnames
    print('Stripping csv_table_ prefixes...')
    strip_prefix_fields(surveys_added, prefix='csv_table_', collision_suffix='_ACC')
    # print record count of surveys_added
    input_record_count = arcpy.management.GetCount(surveys_added)
    print(f'Input table surveys_added has {input_record_count} records')
    # target feature class
    survey_plat = r'V:\\gislu\\_DatabaseConnection\\editgis1.lu.user.dc.sde\\lu.LU.SURV_SurveyPlat'
    print('Schema lock test (target):', arcpy.TestSchemaLock(survey_plat))
    print('Workspace type:', getattr(arcpy.Describe(os.path.dirname(survey_plat)), 'workspaceType', None))
    # check for branched versioning
    desc_fc = arcpy.Describe(survey_plat)
    print('isVersioned:', getattr(desc_fc, 'isVersioned', None))
    print('isBranchVersioned:', getattr(desc_fc, 'isBranchVersioned', None))
    fields = [
        'PLSS_COORD', 'LINK', 'PARCEL_NO'
    # Build explicit source and target field lists including SHAPE@
    src_fields = fields + ['SHAPE@']
    tgt_fields = fields + ['SHAPE@']
    sde_workspace = r'V:\gislu\_DatabaseConnection\editgis1.lu.user.dc.sde'
    edit = arcpy.da.Editor(sde_workspace)
    # Inspect target field types
    tgt_field_types = {f.name: f.type for f in arcpy.ListFields(survey_plat)}
    print('Target field types:', tgt_field_types)
    src_field_types = {f.name: f.type for f in arcpy.ListFields(surveys_added)}
    print('Source field types:', src_field_types)
    try:
        # open edit session
        edit.startEditing(True, True)
        edit.startOperation()
        inserted = 0
        skipped = 0
        with arcpy.da.SearchCursor(surveys_added, src_fields) as s_cur, \
             arcpy.da.InsertCursor(survey_plat, tgt_fields) as i_cur:
            for row in s_cur:
                try:
                    i_cur.insertRow(row)
                    inserted += 1
                except Exception as row_error:
                    print(arcpy.getMessages())
                    print(f'ERROR - Could not insert row: {row_error}')
                    skipped += 1
            print(f'Inserted: {inserted} | Skipped: {skipped}')
        edit.stopOperation()
        edit.stopEditing(True)
    except Exception as e:
        # roll back safely on error
        if edit.isEditing:
            edit.stopEditing(False)
        raise
    # formatted email body
    # prep str for processed surveys
    report_processed = f'Surveys processed: {len(process_surveys)}\n'
        survey_id = survey['survey_id']
        parcel_id = survey['parcel_id']
        report_processed += f'{survey_id}' + '    ' + f'{parcel_id}\n'
    # prep str for surveys missing a parcel id
    report_missing = f'Surveys missing a parcel id: {len(missing_surveys)}\n'
    for survey in missing_surveys:
        report_missing += f'{survey_id}\n'
    # prep str for surveys with multiple parcel ids
    report_multi = f'Surveys with multiple parcel ids: {len(multi_surveys)}\n'
    for survey in multi_surveys:
        report_multi += f'{survey_id}' + '    ' + f'{parcel_id}\n'
    # prep str for surveys with nonetype values
    report_null = f'Surveys with NULL values: {len(surveys_with_null_values)}\n'
    for survey in surveys_with_null_values:
            survey_id = 'NULL'
        else:
        report_null += f'{survey_id}' + '    ' + f'{parcel_id}\n'
    # assembly of email body
    email_body = 'Please review following land survey plats:\n' + '\n'
    email_body += f'{report_processed}\n'
    email_body += f'{report_missing}\n'
    email_body += f'{report_multi}\n'
    email_body += f'{report_null}'
    # send email function used for testing
    send_gmail(
        recipient='[email protected]',
        subject='Survey Plat Report - ' + formatted_date,
        body=email_body
    send_gmail(
        body=email_body
    end_time = time.time()
    run_time = end_time - start_time
    print(f'Runtime: {run_time:.2f} seconds')
## END MAIN
def strip_prefix_fields(feature_class, prefix='csv_table_', collision_suffix='_ACC'):
    Rename fields in `feature_class` that start with `prefix` by stripping the prefix.
    If the target name already exists, append `collision_suffix` with an incrementing number.
    # Build a set of existing field names (lowercase for quick membership checks)
    existing = {f.name.lower() for f in arcpy.ListFields(feature_class)}
    # Iterate all fields and rename those with the prefix
    for f in arcpy.ListFields(feature_class):
        old_name = f.name
        if old_name.startswith(prefix):
            base = old_name[len(prefix):]  # target name without prefix
            new_name = base
            # Handle collisions: ensure unique name
            if new_name.lower() in existing:
                i = 1
                while f"{base}{collision_suffix}{i}".lower() in existing:
                    i += 1
                new_name = f"{base}{collision_suffix}{i}"
            # Use the same alias as the new name (or customize here)
            new_alias = new_name
            # Perform the rename
            arcpy.management.AlterField(
                in_table=feature_class,
                field=old_name,
                new_field_name=new_name,
                new_field_alias=new_alias
            # Maintain the set to reflect the rename
            existing.add(new_name.lower())
            existing.discard(old_name.lower())
            print(f"Renamed field: {old_name} -> {new_name}")
def rename_reorder_df(df, rename_map=None, column_order=None):
    result = df.copy()
    if rename_map:
        result = result.rename(columns=rename_map)
    if column_order:
        result = result[column_order]
    return result
def append_df_to_feature_class(df, feature_class, field_map=None):
    if field_map:
        df = df.rename(columns=field_map)
    fc_fields = [
        f.name for f in arcpy.ListFields(feature_class)
        if f.type not in ('OID', 'Geometry') and not f.required
    matched_fields = [col for col in df.columns if col in fc_fields]
    if not matched_fields:
        raise ValueError('No matching fields found between df and fc')
    rows_inserted = 0
    with arcpy.da.InsertCursor(feature_class, matched_fields) as cursor:
        for row in df[matched_fields].itertuples(index=False, name=None):
            cursor.insertRow(row)
            rows_inserted += 1
    print(f'Rows inserted: {rows_inserted}')
# InsertCursor -----------------------------------------------------------------
def resolve_joined_field(source_fc, target_name):
    Find the actual field name in source_fc that matches target_name,
    allowing for join prefixes like `csv_table_` or `parcels_`.
    source_names = [f.name for f in arcpy.ListFields(source_fc)]
    # exact match
    if target_name in source_names:
        return target_name
    # look for suffix match like xxx_TARGETNAME
    candidates = [
        name for name in source_names
        if name.lower().endswith(target_name.lower())
    if len(candidates) == 1:
        return candidates[0]
    elif len(candidates) > 1:
        # choose the shortest suffix match to avoid over-prefixed names
        return sorted(candidates, key=len)[0]
    else:
        raise RuntimeError(f'Could not resolve source field for: {target_name}')
# End InsertCursor functions ---------------------------------------------------
def query_accela(connection_string, query):
    try:
        connection = pyodbc.connect(connection_string)
        cursor = connection.cursor()
        cursor.execute(query)
        # get key names
        keys = [key[0] for key in cursor.description]
        # create list of dictionaries
        results = [
            dict(zip(keys, row)) for row in cursor
        cursor.close()
        connection.close()
        return results
    except pyodbc.Error as e:
        print(f'Database error: {e}')
        return []
        print(f'Error: {e}')
        return []
def return_by_parcel_id(query_returns):
    surveys_with_parcel_id = []
    surveys_multi_parcel_id = []
    surveys_missing_parcel_id = []
    if len(query_returns) > 0:
        for survey in query_returns:
            if survey['parcel_id'].startswith('0'):
                surveys_missing_parcel_id.append(survey)
            elif len(survey['parcel_id']) > 12:
                surveys_multi_parcel_id.append(survey)
            else:
                surveys_with_parcel_id.append(survey)
    else:
        return False
    return {
        'surveys': surveys_with_parcel_id,
        'multi_id': surveys_multi_parcel_id,
        'missing_id': surveys_missing_parcel_id
def send_gmail(recipient, subject, body):
    gmail_sender = REMOVED
    gmail_app = REMOVED
    try:
        msg = MIMEMultipart()
        # create email
        msg['From'] = gmail_sender
        msg['To'] = recipient
        msg['Subject'] = subject
        msg.attach(MIMEText(body, 'plain'))
        # connect to gmail server and send
        server = smtplib.SMTP_SSL('smtp.gmail.com', 465)
        server.ehlo()
        server.login(gmail_sender, gmail_app)
        text = msg.as_string()
        server.sendmail(gmail_sender, recipient, text)
        server.close()
        print(f'Email sent to: {recipient}')
## END OF ALL FUNCTIONS
if __name__ == '__main__':
    main()
DanPatterson
MVP Esteemed Contributor
line number? for the append step
a copy of the error message, if there was one might be useful
... sort of retired...
Sean_Gambrel
Hi Dan,
Sorry, we're no longer using the append (there has been A LOT of trial and error here), and I've updated the post.  Script runs until around line 359.
HaydenWelch
MVP Regular Contributor
That's kinda a weird way to handle cursor contexts. I'd wrap both in parens instead of using a \ line continuation.
Line continuations are always best avoided since a sneaky whitespace character after the \ will break them and that's almost impossible to find.
Also, the get messages function for arcpy is arcpy.GetMessages() not arcpy.getMessages()
You also never delete your edit session, you should always run an edit session using a with block since a crash out could leave that session active and cause issues down the line since the locks aren't properly cleaned up.
Here's that surrounding code with those edits:
    inserted = 0
    skipped = 0
    with (
        arcpy.da.Editor(sde_workspace) as edit,
        arcpy.da.InsertCursor(survey_plat, tgt_fields) as i_cur,
        for row in s_cur:
            try:
                inserted += 1
                print(arcpy.GetMessages())
                skipped += 1
TonyAlmeida
A few things,
Add this before the cursor block:
# Debug - check actual field names
actual_fields = [f.name for f in arcpy.ListFields(surveys_added)]
print("Actual fields in surveys_added:", actual_fields)
print("Fields we're trying to read:", src_fields)
The join table prefix might be different now (e.g., csv_table_ vs TableFromAccela_ vs something else).
Try this simpler approach - skip the rename and direct field mapping:
# After creating surveys_added, map fields explicitly:
field_mapping = {
    'csv_table_SURVEY_ID': 'SURVEY_ID',
    'csv_table_SURVEY_TYP': 'SURVEY_TYP',
    # ... etc
# Use the mapped names in your cursor
src_fields = list(field_mapping.keys()) + ['SHAPE@']
tgt_fields = list(field_mapping.values()) + ['SHAPE@']
Move the cursor OUTSIDE the edit session:
# FIRST: test reading source
with arcpy.da.SearchCursor(surveys_added, src_fields) as s_cur:
rows = list(s_cur)
# THEN open edit session
with arcpy.da.InsertCursor(survey_plat, tgt_fields) as i_cur:
for row in rows:
RhettZufelt
MVP Notable Contributor
You say there was a change in the database that broke it.
What was the change?
R_
HaydenWelch
I took a shot at cleaning up the logic a bit. There's a ton of joining and pivoting you don't really need to do since you're just using an InsertCursor at the end of the processing. Definitely just use this as a reference to validate your logic since the overall structure is totally different, but sometimes having a different implementation can help you find things:
#              04/21/2026 - rewrite with some example blocks (NOT READY FOR PRODUCTION)
# Set this to True once you've reviewed the code and want to test it
ALLOW_RUN = False
from datetime import date, datetime
from pathlib import Path
import time
from typing import Literal, TypedDict
import arcpy
import pyodbc
import smtplib
#                               Globals                                      #
NOTIFICATIONS = [
    '[email protected]'
PLAT_PROCESSING_DIR = Path(r'V:\prjlu\SurveyPlats\PlatProcessingAutomation')
SDE_DIRECTORY = Path(r'V:\gislu\_DatabaseConnection')
PARCEL_DATABASE = SDE_DIRECTORY  / 'regis1.boco.gis.dc.sde'
SURVEY_PLAT_DATABASE = SDE_DIRECTORY / 'editgis1.lu.user.dc.sde'
MAP_DIRECTORY = Path(r'V:\ScannedMaps\SURVEY\LANDSURVEY')
CONNECTION_STRING = (
    '<REMOVED>'
ACCELA_QUERY = (
SELECT *
FROM V_RECORD
DEFAULT_TITLE = '_NO_TITLE_'
DEFAULT_YEAR = '0000'
DEFAULT_DESCRIPTION = '_NO_DESCRIPTION_'
DEFAULT_SURVEY_LAST_4 = 'xyzx'
class SurveyRecord(TypedDict):
    """Schema from Accela"""
    survey_id: str | None
    docket_type: str | None
    app_date: datetime | None
    document_title: str | None
    description: str | None
    parcel_id: str | None
    address: str | None
class NewSurveyRecord(TypedDict):
    """Target schema for added surveys"""
    SURVEY_ID: str | None
    SURVEY_TYP: str | None
    SURVEY_DES: str | None
    SURVEY_YR: str | None
    PLSS_COORD: Literal['N'] | None
    LINK: str | None
    PARCEL_NO: str | None
REQUIRED_FIELDS = list(NewSurveyRecord.__required_keys__)
def main():
    surveys = query_accela(CONNECTION_STRING, ACCELA_QUERY)
    if not surveys:
        print('No Surveys Found!')
        return
    existing_records: dict[str, arcpy.Polygon] = {
        parcel_no: shape
        for parcel_no, shape
        in arcpy.da.SearchCursor(
            str(PARCEL_DATABASE / 'boco.PARCELS.PARCELS'),
            ['PARCEL_NO', 'SHAPE@']
    new_surveys = [
        process_accela_survey(survey)
        if has_required(survey)
        and survey['parcel_id'] in existing_records
    null_surveys: list[SurveyRecord] = [
        survey for survey in process_surveys
        if not has_required(survey)
        or survey['parcel_id'] not in existing_records # Seperate group?
    input_record_count = len(new_surveys)
    survey_plat = SURVEY_PLAT_DATABASE / 'lu.LU.SURV_SurveyPlat'
    _waited = 0
    while not arcpy.TestSchemaLock(str(survey_plat)):
        if _waited > 60:
            # Timeout after a minute
            raise TimeoutError(f'Unable to obtain schema lock for {survey_plat.name} within 60 seconds')
        print(f'Wating for schema lock ({_waited}s/60s)...')
        time.sleep(1)
        _waited += 1
    with (
        arcpy.da.Editor(str(SURVEY_PLAT_DATABASE)),
        arcpy.da.InsertCursor(str(survey_plat), ['SHAPE@'] + REQUIRED_FIELDS) as cur
        fields = cur.fields
        for new_survey in new_surveys:
            if not new_survey['PARCEL_NO']: # This should never happen
                print(f'Skipping Processed Survey Record with no associated parcel number: {new_survey}')
                continue
            shape = existing_records[new_survey['PARCEL_NO']]
            cur.insertRow([shape] + [new_survey[field] for field in fields])
    email_body = build_email_body(process_surveys, missing_surveys, multi_surveys, null_surveys)
    for recipient in NOTIFICATIONS:
        send_gmail(
            recipient=recipient,
            subject=f'Survey Plat Report - {formatted_date}',
            body=email_body)
def build_email_body(
    process_surveys: list[SurveyRecord],
    missing_surveys: list[SurveyRecord],
    multi_surveys: list[SurveyRecord],
    null_surveys: list[SurveyRecord],
) -> str:
    # NOTE: Should probably add a body component to show total number of rows inserted
    #rows_added = len(new_surveys)
    report_processed = (
        f'Surveys processed: {len(process_surveys)}\n',
        f'{get_info(process_surveys, ['survey_id', 'parcel_id'])}'
    report_missing = (
        f'{get_info(missing_surveys, ['survey_id'])}'
    report_multi = (
        f'{get_info(multi_surveys, ['survey_id', 'parcel_id'])}'
    report_null = (
        f'Surveys with NULL values: {len(null_surveys)}\n'
        f'{get_info(null_surveys, ['survey_id', 'parcel_id'])}'
    email_body = 'Please review following land survey plats:\n\n'
    return email_body
def get_info(accela_surveys: list[SurveyRecord], fields: list[str]) -> str:
    return '\n'.join('    '.join(str(s.get(f) or 'NULL') for f in fields) for s in accela_surveys)
def has_required(accela_survey: SurveyRecord, required: list[str] | Literal['all', 'none'] = 'all') -> bool:
    if required == 'none':
        return True
    elif required == 'all':
        return all(accela_survey.values())
    else:
        return all(accela_survey.get(field) for field in required)
def process_accela_survey(accela_survey: SurveyRecord) -> NewSurveyRecord:
        new_survey: NewSurveyRecord = {
            'SURVEY_ID': None,
            'SURVEY_TYP': None,
            'SURVEY_DES': None,
            'SURVEY_YR': None,
            'PLSS_COORD': None,
            'LINK': None,
            'PARCEL_NO': None,
        new_survey['SURVEY_ID'] = accela_survey['survey_id']
        new_survey['PARCEL_NO'] = accela_survey['parcel_id']
        type_map = {
            'IMPR': 'Improvement Survey Plat',
            'ALTA': 'Land Survey Plat',
            'LAND': 'Land Survey Plat',
        new_survey['SURVEY_TYP'] = type_map.get(
            # Get the document title survey_type if it exists
            (accela_survey['document_title'] or DEFAULT_TITLE)[:4],
            # or Default survey_type
        survey_descr = (accela_survey['description'] or '_NO_DESCRIPTION_')
        descr_map = {
            'SECTION ': 'SEC',
            'SEC. ': 'SEC',
            'SEC ': 'SEC',
            'TOWNSHIP': 'T',
            'RANGE': 'R',
            'QUARTER': '1/4',
            # NOTE: NORTHEAST etc. will be replaced as NORTH -> N EAST -> E
            'NORTH': 'N',
            'SOUTH': 'S',
            'EAST': 'E',
            'WEST': 'W'
        for original, abbreviation in descr_map.items():
            if original in survey_descr:
                survey_descr = survey_descr.replace(original, abbreviation)
        final_description = (accela_survey['document_title'] or DEFAULT_TITLE) + ', ' + survey_descr
        new_survey['SURVEY_DES'] = final_description[:254]
        new_survey['SURVEY_YR'] = str(accela_survey['app_date'].year) if accela_survey['app_date'] else DEFAULT_YEAR
        new_survey['PLSS_COORD'] = 'N'
        year_last_2 = new_survey['SURVEY_YR'][-2:]
        survey_id_last_4 = accela_survey['survey_id'][-4:] if accela_survey['survey_id'] else DEFAULT_SURVEY_LAST_4
        suffix = '-01'
        file_ext = '.pdf'
        new_survey['LINK'] = str(MAP_DIRECTORY / filename)
        return new_survey
def query_accela(connection_string: str, query: str) -> list[SurveyRecord]:
    try:
        with pyodbc.connect(connection_string).cursor() as cursor:
            keys = [k[0] for k in cursor.description]
            return [dict(zip(keys, row)) for row in cursor] # type: ignore
    return []
_ReturnKeys = Literal['surveys', 'multi_id', 'missing_id']
def return_by_parcel_id(query_returns: list[SurveyRecord]) -> dict[_ReturnKeys, list[SurveyRecord]]:
    surveys_with_parcel_id: list[SurveyRecord] = []
    surveys_multi_parcel_id: list[SurveyRecord] = []
    surveys_missing_parcel_id: list[SurveyRecord] = []
        if survey['parcel_id'] and survey['parcel_id'].startswith('0'):
        elif survey['parcel_id'] and len(survey['parcel_id']) > 12:
        else:
    return {
def send_gmail(recipient: str, subject: str, body: str):
    gmail_sender = '<REMOVED>'
    gmail_app = '<REMOVED>'
    try:
        # create email
        server.ehlo()
        server.close()
    if ALLOW_RUN:
        main()
