Python Problem
6644
11
12-02-2014 02:34 PM
DavidLeslie
I am trying to write a script that that changes the aliases of a table's fields, but when I ran it I got this code error:
ExecuteError: ERROR 001601: Failed to alter field alias.
Failed to execute (AlterField).
This makes no sense to me and I would love any input as to why this happened.
Also, here is my code that generated this error:
# Import geoprocessing
import arcpy
# Set workspace
arcpy.env.workspace = r'U:\newberry\new.gdb'
# Creates a list of fields from the Metadata_2010 table
fieldListTable = arcpy.ListFields("METADATA_2010")
# Creates a cursor - a data access object
rows = arcpy.SearchCursor("METADATA_2010")
# Creates an empty table to store row values
fullNames = []
# For loop thats iterates through the rows in
# the Full_Name field of the Metadata_2010 table
for row in rows:
    # Adds the row value to the fullNames list
    fullNames.append(row.getValue(fieldListTable[2].name))
# Creates a sliced list of fields from the census block group
# polygon feature class
fieldList = arcpy.ListFields("please")[2:630]
# For loop thats changes the existing alias name in the table
# to the name in the fullNames list
for i in range(len(fieldList)):
    arcpy.AlterField_management('please', str(fieldList.name),'',str(fullNames))
DavidLeslie
I did not use the descriptions from the metadata as field names, I used them as aliases. I'm guessing that replacing field names have some limitations on the length, where alias don't .
Zeke
Honored Contributor
Thanks. I may use this myself. I did write a script to delete the 'Margin of Error' fields. Not relevant for our uses, and they double the number of fields. My data wasn't joined to the polygon file, though, when I downloaded it. Relationship classes are there, but not actually working.
