Python: parse/extract json returned from locator service?
1432
03-21-2019 10:36 AM
AllenScully
In a python script to be published as a GP service, I'm making a call to a Locator Service, getting results back - plan is to use the X & Y values from the locator return as input variables for some intersects etc. as part of the overall tool.
The call/return from the locator is working, now I'm investigating the python json library to figure out how the extract just X & Y values into variables.
My question is about whether/how you can use the json library to parse through the json and return the 2 attributes (the X and Y in my case) so they can be plugged into python variables..
Results example:
{u'candidates': [{u'attributes': {u'Y': 446768.471952, u'X': 992202.058741}, u'score': 100, u'location': {u'y': 446768.47195232206, u'x': 992202.0587409921}, u'address': u'201 N STONE AV, TUCSON'}], u'spatialReference': {u'wkid': 2868, u'latestWkid': 2868}}
Alternately, after simply converting the Results to a string:
"spatialReference": {
"wkid": 2868,
"latestWkid": 2868
"candidates": [
"address": "201 N STONE AV, TUCSON",
"location": {
"x": 992202.0587409921,
"y": 446768.47195232206
"score": 100,
"attributes": {
"X": 992202.05874100002,
"Y": 446768.47195199999
Anyone been through this before?
Thanks -
Allen
DanPatterson_Retired
Looks like dictionaries, extract the 'candidates' you have one candidate so a simple list slice [0] which gives you the remaining bits
d = {u'candidates': [{u'attributes': {u'Y': 446768.471952, u'X': 992202.058741},
     u'score': 100,
d['candidates'][0]['attributes']
Out[7]: {'Y': 446768.471952, 'X': 992202.058741}
d['candidates'][0]['attributes']['Y']
Out[8]: 446768.471952‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
I did find this nifty dictionary unpacking function though
def extract_nested_values(it):
    if isinstance(it, list):
        for sub_it in it:
            yield from extract_nested_values(sub_it)
    elif isinstance(it, dict):
        for value in it.values():
            yield from extract_nested_values(value)
    else:
        yield it
print(list(extract_nested_values(d)))
[446768.471952, 992202.058741, 100, 446768.47195232206, 992202.0587409921, '201 N STONE AV, TUCSON', 2868, 2868]‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
You only have one row of data, so that is why the print is only one row long
It returns a generator so you convert it to a list and assign to a variable if needed
result = list(extract_nested_values(d))‍‍
one of loads of references
python - Cleaner way to unpack nested dictionaries - Stack Overflow
forestknutsen1
You can move freely between json and a python dict.
Converting Dictionary to JSON in python - Stack Overflow
