Python Label Expression; Using multiple if's to label fields > 0
10198
13
03-02-2015 08:39 AM
MCAGIS
I've written this code, and the expression checks out, but it only labels the first field. Can someone tell me why it doesn't run through the rest of the if's to create a stacked label with field >0?
def FindLabel ( [Light_Numb], [IN_FDN] , [IN_35_FT_METAL_POST] , [IN_35_5] , [IN_40_5] , [IN_6_FT_ARM] , [IN_12_FT_ARM] , [IN_18_FT_ARM] , [IN_X_ARM] , [IN_LED_87W_OH] , [IN_LED_101W_OH] , [IN_LED_110W_OH] , [IN_LED_260W_OH] , [IN_LED_87W_UG] , [IN_LED_101W_UG] , [IN_LED_110W_UG] , [IN_LED_260W_UG] , [IN_PC] , [IN_SC] , [CONC_WORK_REQ_SQ_FT]  😞
try:
    if [Light_Numb] > 0:
        return [Light_Numb]
    '\n'
    if [In_FDN] > 0:
        return 'In FDN', [IN_FDN]
    '\n'
    if [IN_35_FT_METAL_POST] > 0:
        return 'IN 35 FT METAL POST', [IN_35_FT_METAL_POST]
    '\n'
    if [IN_35_5] > 0:
        return 'IN 35-5', [IN_35_5]
    '\n'
    if [IN_40_5] > 0:
        return 'IN 40-5', [IN_40_5]
    '\n'
    if [IN_6_FT_ARM] > 0:
        return 'IN 6 FT ARM', [IN_6_FT_ARM]
    '\n'
    if [IN_12_FT_ARM] > 0:
        return 'IN 12 FT ARM', [IN_12_FT_ARM]
    '\n'
    if [IN_18_FT_ARM] > 0:
        return 'IN_18 FT ARM', [IN_18_FT_ARM]
    '\n'
    if [IN_X_ARM] > 0:
        return 'IN X ARM', [IN_X_ARM]
    '\n'
    if [IN_LED_87W_OH] > 0:
        return 'IN LED 87W', [IN_LED_87W_OH]
    '\n'
    if [IN_LED_87W_UG] > 0:
        return 'IN LED 87W', [IN_LED_87W_UG]
    '\n'
    if [IN_LED_101W_OH] > 0:
        return 'IN LED 101W', [IN_LED_101W_OH]
    '\n'
    if [IN_LED_101W_UG] > 0:
        return 'IN LED 101W', [IN_LED_101W_UG]
    '\n'
    if [IN_LED_110W_OH] > 0:
        return 'IN LED 110W', [IN_LED_110W_OH]
    '\n'
    if [IN_LED_110W_UG] > 0:
        return 'IN LED 110W', [IN_LED_110W_UG]
    '\n'
    if [IN_LED_260W_OH] > 0:
        return 'IN LED 260W', [IN_LED_260W_OH]
    '\n'
    if [IN_LED_260W_UG] > 0:
        return 'IN LED 260W', [IN_LED_260W_UG]
    '\n'
    if [IN_PC] > 0:
        return 'IN PC', [IN_PC]
    '\n'
    if [IN_SC] > 0:
        return 'IN SC', [IN_SC]
    '\n'
    if [CONC_WORK_REQ_SQ_FT] > 0:
        return 'CONC WORK REQ SQFT', [CONC_WORK_REQ_SQ_FT]
except:
return 'None'
JoshuaBixby
MVP Esteemed Contributor
Can you post some specific error messages?  Also, what about a table/feature class with a subset of your data?  I tested the code on some examples I created without issue, but obviously my guessing on your data structure wasn't right.
DavidFox
Maybe the attached table will help.
And of course the error message in ArcGIS isn't selectable to copy and paste ...
DarrenWiens2
You must (?) enclose your field names in brackets (as you did long before) in the label expression FindLabel function :
def FindLabel ( [stand_code], [Avg_TPA_Pine], [Avg_TPA_Cyp], [Avg_TPA_Hdwd] ):
JoshuaBixby
I will save any explanations until after I see whether this works for you:
def FindLabel ( [stand_code], [Avg_TPA_Pi], [Avg_TPA_Cy], [Avg_TPA_Hd] ):
    stand_code = [stand_code]
    Avg_TPA_Pine = [Avg_TPA_Pi]
    Avg_TPA_Cyp = [Avg_TPA_Cy]
    Avg_TPA_Hdwd = [Avg_TPA_Hd]
    label = ""
    try:
          if int(Avg_TPA_Pine) > 0:
              label += "TPA P: " + Avg_TPA_Pine + " / "
          if int(Avg_TPA_Cyp) > 0:
              label += "TPA C: " + Avg_TPA_Cyp + " / "
          if int(Avg_TPA_Hdwd) > 0:
              label += "TPA H: " + Avg_TPA_Hdwd
          return stand_code + '\n'+ label
    except:
          return  stand_code
