Python Help
3942
6
12-10-2014 08:22 AM
DavidLeslie
Is there a way I can create a list of only the deletable fields in a feature class (and by deletable I mean fields other than OBJECTID, Shape, etc . I tried using arcpy.ListFields(), but it list all of the feilds.
DavidBlanchard
You will have to filter your list of fields produced by arcpy.ListFields() using the properties of the Field object. If you need help on filtering your list, the Dive Into Python guide has an excellent chapter on this: 4.5. Filtering Lists.
DavidBlanchard
DavidLeslie
Thanks for your quick reply! From your post, I realized that I could use the editable method to check to see if a field can be deleted or not!
DanPatterson_Retired
just be aware of the subtle difference between editable and required
Editable fields:
[[False, u'FID'], [True, u'Shape'], [True, u'Id'], [True, u'X'], [True, u'Y'], [True, u'Label']]
Required fields:
[[True, u'FID'], [True, u'Shape'], [False, u'Id'], [False, u'X'], [False, u'Y'], [False, u'Label']]
like this...
>>> import arcpy
>>> shp_file = "c:/temp/x.shp"
>>> flds = arcpy.ListFields(shp_file)
>>> req_flds = [ [fld.required, fld.name] for fld in flds]
>>> req_flds
DavidLeslie
I just used:
for i in range(len(parcelFieldList)):
     if parcelFieldList.editable:
          parcelFieldNames.append(str(parcelFieldList.name))
curtvprice
List comprehensions are just so elegant.
efields = [f.name for f in arcpy.ListFields(table) if f.editable]
