Python email question
4319
08-05-2019 01:58 PM
MarcoPretorius1
I am trying to send a email using the smtplib package and am getting the following error:
Script:
  1. import smtplib
  2. server_ssl = smtplib.SMTP_SSL('smtp.office365.com', xxx)
  3. server_ssl.ehlo() # optional, called by login()
  4. server_ssl.login('[email protected]', 'xx')
  5. # ssl server doesn't support or need tls, so don't call server_ssl.starttls()
  6. server_ssl.sendmail("[email protected]", "[email protected]", "hello")
  7. #server_ssl.quit()
  8. server_ssl.close()
  9. print 'successfully sent the mail'
Error:
File "Script5.py", line 3, in <module>
File "C:\Python27\ArcGIS10.7\lib\smtplib.py", line 802, in __init__
SMTP.__init__(self, host, port, local_hostname, timeout)
File "C:\Python27\ArcGIS10.7\lib\smtplib.py", line 259, in __init__
raise SMTPConnectError(code, msg)
smtplib.SMTPConnectError: (-1, 'The Microsoft Exchange IMAP4 service is ready. [QgBOADYAUABSADEAMQBDAEEAMAAw]')
Any help is appreciated. Thank you! #
by Anonymous User
Not applicable
Refer the following sample code which might be helpful for you.
#system Modules
import httplib
import smtplib
from email.MIMEText import MIMEText
# script
host = "xxxxx-xxxx.xxx"
fromAdd = "fromemailaddress_Admin"
toAdd = "Your email address"
msg = MIMEText(stringInput)
msg['Subject'] = "Subject"
msg['From'] = fromAdd
msg['To'] = toAdd
s = smtplib.SMTP()
s.connect(host)
s.sendmail(fromAdd, msg["To"].split(","), msg.as_string())
s.close()
