[Python] download feature service from AGOL to folder
3328
07-19-2021 12:29 PM
by Anonymous User
Not applicable
Using Python I am would like to take files from agol and download them onto my laptop as shapefile.  Does anyone have code that they could share with me?  I am new to python
Tags (1)
curtvprice
Here's an example using the gis module:
How can I export a Feature Layer in AGOL to Shapefile, using API for Python?
https://community.esri.com/t5/arcgis-api-for-python-questions/how-can-i-export-a-feature-layer-in-ag...
HamishMorton
There is a useful code sample in the following link showing how to download all items owned by a particular user - How To: Download feature service items from ArcGIS Online using ArcGIS API for Python (esri.com):
import arcgis
from arcgis.gis import GIS
gis = GIS(None,'username', 'password', verify_cert=False)
# Download all data from a user
def downloadUserItems(owner, downloadFormat):
    try:
        # Search items by username
        items = gis.content.search('owner:{0}'.format(owner))
        print(items)
        # Loop through each item and if equal to Feature service then download it
        for item in items:
            if item.type == 'Feature Service':
                result = item.export('sample {}'.format(item.title), downloadFormat)
                result.download(r'file path of where to store the download')
                # Delete the item after it downloads to save on space
                result.delete()
    except Exception as e:
        print(e)
# Function takes in two parameters. Username and the type of download format
downloadUserItems('username', downloadFormat='Shapefile')
Alternatively, if you have access to arcpy you could use the Feature Class to Feature Class tool - Feature Class To Feature Class (Conversion)—ArcGIS Pro | Documentation
Finally, the following post may also be of use - Solved: Re: Downloading AGOL feature as Excel file and sha... - Esri Community
Best,
Hamish
Hamish
WillemVan_Riet1
Hi, I posted an error when I tried the code sample from How To: Download feature service items from ArcGIS Online using ArcGIS API for Python (esri.com):
# define the download format and the specified output path
# path = my_test_path ## changed for forum post
    try:
#         items = gis.content.search('owner:{0}'.format(owner))
#         print(items)
        # search items by group
        group = gis.groups.search("title:ArcGIS API Test", max_groups=15)[0]
        items = group.content()
        print(items)
        for item in items:
            print(item.type)
           # if item.type in ['Feature Service', 'Vector Tile Service', 'Scene Service']:
            result = item.export('sample {}'.format(item.title), downloadFormat, wait =True)
            result.download(path)
            # Delete the item after it downloads to save space (OPTIONAL)
           # result.delete()
            print("Exported item: {}".format(result))
        print(e)
downloadUserItems('dsfgis', downloadFormat='Shapefile')
 And I get this error:
[<Item title:"Storm_Feature" type:Feature Layer Collection owner:dsfgis>]
Feature Service
Could not export item.
 Your help/insights would be appreciated!
