Python directory question
2242
6
06-14-2019 07:34 AM
MarcoPretorius1
import arcpy
from arcpy import da
import os
attachTable = 'C:\users\user\Test2\pictures.gdb\pictures__ATTACH' # Table in GDB holding attatchments
origTable = 'C:\Users\user\Test2\pictures.gdb\pictures' # Layer in GDB holding features to which attatchments belong
nameField = 'Name' # Field where you want to save the photos
fileLocation = 'C:\Users\user\pictures\pics' # folder where you want to save the photos
# creates a cursor to search through the attachment tables; specify yu only wish to search those three fields
attachCursor = arcpy.da.SearchCursor(attachTable, ['DATA', 'ATT_NAME', 'REL_GLOBALID'])
# Begin searching the table and storing the actual images, movies, etc.
for attRow in attachCursor:
binaryRep = attRow[0]
filename = attRow[1]
relID = attRow[2]
# creates a cursor to sort the features; essentially to find a match fro the relID above
originCursor = arcpy.da.SearchCursor(origTable, ['GLOBALID', nameField])
for origRow in originCursor:
origID = origRow[0]
origName = origRow[1]
if origID == relID:
break
# Saves a file in the specified location tht contains the name chosen by the user for the attachment
open(fileLocation + os.sep + origName + ".jpg", 'wb').write(binaryRep.tobytes())
# deletes search cursor
del originCursor
ERROR
File "C:/Users/mpretorius/Desktop/att.py", line 28, in <module>
IOError: [Errno 2] No such file or directory: u'C:\\Users\\user\\pictures\\pics\\HGC-2.jpg'
Can't seem to figure out what is wrong in this script. Any help appreciated!
Egge-Jan_Pollé
Hi Marco Pretorius,
The quickest solution would be to replace all backward slashes in your directory paths to forward ones.
So 'C:\users\user\Test2\pictures.gdb\pictures__ATTACH' should become 'C:/users/user/Test2/pictures.gdb/pictures__ATTACH', etcetera.
And then save and run the script again 🙂
Does this solve your issue?
Cheers,
Egge-Jan
MarcoPretorius1
Getting this error
File "C:/Users/user/Desktop/att.py", line 28, in <module>
IOError: [Errno 2] No such file or directory: u'C:/Users/user/pictures/pics/\\HGC-2.jpg'
Any further suggestions?
Egge-Jan_Pollé
The issue might be caused by the two backslashes in the filename: C:/Users/user/pictures/pics/\\HGC-2.jpg
You should try to find out where these come from.
JoshuaBixby
MVP Esteemed Contributor
The Python open command will not be able to create a directory if it doesn't exist, just a file, so make sure all of the directories in the path exist prior to running that command.
DanPatterson_Retired
for line numbers to facilitate references to script lines see
/blogs/dan_patterson/2016/08/14/script-formatting
You should have gotten failures way before you did.
You need to raw encode your paths little 'r'
p = 'C:\users\user\Test2\pictures.gdb\pictures__ATTACH'
  File "<ipython-input-2-3d412528dd89>", line 1
SyntaxError: (unicode error) 'unicodeescape' codec can't decode bytes in position 2-3: truncated \uXXXX escape
p = r'C:\users\user\Test2\pictures.gdb\pictures__ATTACH'  # --- raw encoded
# use all forward slashes
