Python Coding to Automate Map Generation from Bookmarked Extents to PDF With Predefined Template To PDF
3248
11-25-2015 09:34 AM
EricBarr
Hello,
I am working on a python script to automate map creation from bookmarked extents in ArcGIS10.3. I want to create a template, with a north arrow, uniform legend, dynamic title (based on bookmarked layer/view extent), dynamic scale bar (based on extent of bkmk view), and static author name.  I also want to have an inset map to show the whole study area.
Do you have any suggestions?   I am thinking of modifying the scripting already available to generate map books as pdfs using the fishnet index tool.
Thanks for your suggestions!
DanPatterson_Retired
Moving to Python so that you have a better chance of getting help.  GeoNet Help is about getting help on GeoNet
RickeyFight
MVP Regular Contributor
Eric,
Is there a reason you are not using Data driven pages?
ArcGIS Desktop
