Python Code to Load Feature Service to AGOL Not Working- 10.2 Issue?
3231
08-27-2013 11:23 AM
JonathanFarmer1
I have been using the code provided by Jeff Moulds in this thread to add feature services to AGOL:
http://forums.arcgis.com/threads/80680-How-to-publish-a-feature-service-to-ArcGIS-Online-from-an-mxd...
It has worked just fine in 10.1 but now I am getting an error and I think it may have something to do with 10.2
Traceback (most recent call last):   File "J:\GIS\Parcel_Data\Python_Data\Auto_Load_AGOL.py", line 60, in <module>     arcpy.UploadServiceDefinition_server(sd, con)   File "C:\Program Files\ArcGIS\Desktop10.2\arcpy\arcpy\server.py", line 1293, in UploadServiceDefinition     raise e ExecuteError: Failed to execute. Parameters are not valid. ERROR 000732: Server: Dataset My Hosted Services does not exist or is not supported Failed to execute (UploadServiceDefinition).
I have not changed anything with the code since it last worked in 10.1 so I can't think of anything else it could be?
Jonathan
JakeSkinner
Esri Esteemed Contributor
Hi Jonathan,
This is unfortunately a bug at 10.2, and has been logged, #NIM093766:  When uploading to My Hosted Services, arcpy.UploadServiceDefinition fails with error "000732 Server: Dataset My Hosted Services does not exist or is not supported".].
The severity of the bug has been marked as High.  The only workaround at the moment is to manually upload the service.
JakeSkinner
Hi Jonathan,
JonathanFarmer1
Thanks Jake. I guess I will await the first service pack for a fix hopefully.
AdamTonkin
Hi Jonathan,
Hi - did this fix make it into 10.2.2 release?  Just checking....
JakeSkinner
Hi Adam,
It doesn't look like it has.  You can check the bugs addressed in the coming 10.2.2 release from the following link:
http://downloads.esri.com/support/downloads/other_/1022-IssuesAddressedList.pdf
DamonPettitt
Do the steps in this blog post (which use ArcGIS.com REST API techniques instead of arcpy.SignInToPortal_server) get around this bug?
Updating your hosted feature service for 10.2 | ArcGIS Blog
