What packages will stop supporting 2.7 Don't panic, ArcMap will still be using it... at least for 10.7
Numpy/Scipy drops support of python 2.7 Dec 31, 2018 get your code ready
Guido speaks 2020 is the big end The BDFL, Guido speaks at PyCon 2016 about python 2.7
Announcement Overview — Python 3.7.0a0 documentation yes... 3.7 is on its way
Announcement What’s New In Python 3.6 — Python 3.6.0b2 documentation final release candidate
iPad and iThings Python 3.5 comes to iThings don't get further behind...
Additional The key differences between python 2 and 3
Some frivolity ... but some resources
do check the resources section.
also, here Coming to Python.... preparation and anticipation
I need to make my own retirement count-down webpage. If all goes well it'll be about the same as v2 python.... ![]()
me too... but sadly, I have to teach 3.4 ... for the most part 2to3 fixes stuff and print("is your friend") and print "is old school"
Most of my code is still in Python 2.7 as I'm still using ArcGIS 10.3 I'll have to convert a substantial amount of code once I start using Python 3.4 ![]()
Peter
lots of resources here Coming to Python.... preparation and anticipation
2to3.py will give you a heads up
print is the big one
everything is now unicode (time to learn format mini-language)
range instead of xrange
iterators changed a bit
check py...links for others
another ... the key differences between python 2 and python 3
Do note, the python 3.5 comes to the iThings link, for those getting farther behind. Who needs a story map on your iPhone when you can have an interpolated 3D surface from matplotlib... ![]()
datetime is also an issue
Need help getting year from a date field (field calculator) for a disussion
python link 8.1. datetime — Basic date and time types — Python 3.5.1 documentation
and the esri arcpy fix until everyone is on python 3.x
What’s New In Python 3.7 — Python 3.8.0a3 documentation python 3.8 development.. ns timing and time
3.7.3 Documentation latest stable
What’s New In Python 3.7 — Python 3.7.3 documentation then you can scroll back in time
