Pylance in VS Code
10265
10-27-2023 07:27 AM
HaydenWelch
MVP Regular Contributor
Been having issues with the latest Pylance for VS Code not properly following arcpy imports and specifically hanging up the Pylance server on the arcpy imports meaning all syntax highlighting for any python script is lost.
Not sure if this is an ESRI bug (the hangup makes me think it might have something to do with the licensing server?), but as of now the workaround is reverting back to v2023.7.40
Example of what the latest Pylance shows:
Example of proper behavior with the old Pylance
DanPatterson
MVP Esteemed Contributor
apparently there are issues reported on github
Syntax highlighting and code completion stops working in v2023.9.10 onwards · Issue #5021 · microsof...
some had success with  v2023.10.40
... sort of retired...
DanPatterson
BuffaloCoWI
They introduced this bug a while back (see issue 4862), fixed it in a pre-release version, then must not have merged the fix in the latest release.
