Py 2.4 - using sys.argv with gp.Feature Class to Coverage
2939
11
02-07-2012 06:58 AM
DebraGajdos
Hello everyone,
I am trying to put the gp tool into a script (see my post about os.walk and sys.argv). The proccessing tool looks like this in script form:
# Import system modules
import sys, string, os, arcgisscripting
# Create the Geoprocessor object
gp = arcgisscripting.create()
# Set the necessary product code
gp.SetProduct("ArcInfo")
# Load required toolboxes...
gp.AddToolbox("C:/Program Files/ArcGIS/ArcToolbox/Toolboxes/Conversion Tools.tbx")
# Script arguments..
##lines_shp = sys.argv[1]
lines_shp = "C:\\test\\lines.shp"
# Local variables...
# Process: Feature Class To Coverage...
gp.FeatureclassToCoverage_conversion("C:\\test\\lines.shp ARC", lines_cov, "", "DOUBLE")
This works when I run it in IDLE ver 1.1.1.
But when I try to use the sys.arg like this:
lines_shp = sys.argv [1]
##lines_shp = "C:\\test\\lines.shp"
gp.FeatureclassToCoverage_conversion("lines_shp ARC", linesCopy_cov, "", "DOUBLE")
I get this error:
File "C:/scripts/FC to Cov script.py", line 29, in ?
NameError: name 'linesCopy_cov' is not defined
So I guess my question is, why does FC to Coverage only play nice if the path is hard coded into the gp line? I've written other scripts and used sys.argv with no problem...
Thanks in Advance.
DarrenWiens2
I'm surprised that the first example works - in both examples your output coverage is an undefined variable (ie. you haven't said what either 'lines_cov' or linesCopy_cov' are). Also, are you trying to make a coverage or a shapefile as output (they are different things)?
RDHarles
I agree with Darren that you haven't defined linesCopy_cov  --> but also the first argument should look like this:
gp.FeatureclassToCoverage_conversion(lines_shp+" ARC", linesCopy_cov, "", "DOUBLE")
curtvprice
I think your code just needs a little debugging
lines_shp = sys.argv[1] # or: gp.getParameterAsText(0) (yes, 0)
linesCopy_cov = sys.argv[2] # or: gp.getParameterAsText(1)
gp.FeatureclassToCoverage_conversion(lines_shp + " ARC", linesCopy_cov, "", "DOUBLE")
GetParameterAsText() works better with more complex variables like coordinate systems, so I now use it instead of sys.argv. Except for sys.argv[0] which convenienely contains the path of the script (say, to help you find paths to associated scripts or tools).
DebraGajdos
Sorry, I didn't clean up the code properly.
Ok, here it is from the very begining of the story...I start with Model Builder in ArcGIS 9.2.
I create a model for the input (lines.shp), the output (lines_cov) and the the gp tool (gp.FeatureclassToCoverage_conversion("# ARC", lines_cov, "", "DOUBLE").  I set the input and output features as Parameters.
When I run the Model from the Toolbox, I get a new coverage in my root directory.
I export the Model to Python:
# Script arguments...
lines_cov = sys.argv[2]
When I add the script to a Toolbox, set the parameters, and then run it from Toolbox, I get this error in the dialog window:
Executing (OnlyFC2Cov_8): OnlyFC2Cov C:\test\lines.shp C:\test\lines_cov
Start Time: Tue Feb 07 16:36:06 2012
Running script OnlyFC2Cov...
Error in script OnlyFC2Cov.
Error in executing: cmd.exe /C Q:\scratch\FC_Cov.py  "C:\test\lines.shp" "C:\test\lines_cov"
Failed to execute (OnlyFC2Cov_8).
End Time: Tue Feb 07 16:36:06 2012 (Elapsed Time: 0.00 seconds)
Now, what could be the difference between running this in Model Builder and running as a script?
Eventually, this will be incorporated into a script that uses os.walk to go through a directory tree.
Any help would be appreciated.
RDHarles
Only thing that looks wrong to me is to change this line to:
gp.FeatureclassToCoverage_conversion(lines_shp+" ARC", lines_cov, "", "DOUBLE")
DebraGajdos
Holy Moly!
I would have never guessed to use the "+"!  That does not seem intuitive to me.
Thank you very much!
DarrenWiens2
The difference is that the Model Builder -> Script translator hardly ever works exactly right...
curtvprice
I know you're obviously using 9.3, but I want to add to the thread that you can do "os.walk" type things with a model easily with ModelBuilder 10.0 iterator tools. It's one of the things that make 10.0 worth the hassles.
But even in 9.3, if you have a working model, you can call the model it from a python script -- no need to export/edit in Python:
... os.walk code ...
    gp.AddToolbox(r"x:\path\to\my\toolbox.tbx")
    gp.MyModelTool_mytools(arg1,arg2)
RDHarles
Holy Moly!
It's simply something that's required when you combine a variable (lines_shp) with a string (" ARC").
