Put Raster Properties into table
2164
9
10-05-2012 05:12 AM
JannWendt
maybe someone is able to help me with my problem (I'm new to python :)):
I try to get some raster data into a table with a python script but I get the following error:
File "C:/Users/Jann/Dropbox/EGEOS/Büro/2012/Projekte/Georeferenzierung in Attributtabelle/Online.py", line 21, in <module>
row.top = arcpy.GetRasterProperties_management(raster, "top")
File "C:\Program Files (x86)\ArcGIS\Desktop10.0\arcpy\arcpy\arcobjects\_base.py", line 35, in __setattr__
return setattr(self._arc_object, attr, ao)
ValueError: Row: Invalid input value for setting
My script looks like this:
import arcpy
from arcpy import env
env.workspace = "E:/Data/X-005"
# Create table
if arcpy.Exists("E:/Data/X-005/Test.dbf"):
arcpy.Delete_management("E:/Data/X-005/Test.dbf")
table = arcpy.CreateTable_management("E:/Data/X-005", "Test.dbf")
# Add fields
arcpy.AddField_management(table, "name", "TEXT")
arcpy.AddField_management(table, "top", "TEXT")
# Insert values
rows = arcpy.InsertCursor("E:/Data/X-005/Test.dbf")
rasters = arcpy.ListRasters()
for raster in rasters:
row = rows.newRow()
row.name = raster
rows.insertRow(row)
# Delete cursor and row objects ro remove locks on the data
del row
del rows
Maybe someone can give me some tipps.
Best regards,
Jann
JakeSkinner
Esri Esteemed Contributor
Hi Jann,
Change the following line:
to:
row.top = str(arcpy.GetRasterProperties_management(raster, "top"))
curtvprice
Thanks, Jake, I learned something new today. If you str() a result object, you'll get a string representation of its the result's value. If you know this is a single value and what type it is, this does make for a simple way to get the value:
>>> r = arcpy.GetRasterProperties_management("cdl20091.tif","top") # result object
>>> r
<Result '3173073.79641599'>
>>> r.getOutput(0)  # result object output
u'3173073.79641599'
>>> str(r) # returns string rep of result output
'3173073.79641599'
>>> float(str(r)) # convert to float
3173073.79641599
JannWendt
Thank you both! JSkinn3 for the right way and curtvprice for the explanation 🙂
JannWendt
Okay now Ive an additional question which makes it a little bit more complicated... 😄
With the code above it is possible to get the information about the georeference of rasters in one folder into a .dbf file. My problem is that my folder structure is a little bit different. The rasters are distributed in subfolders. Does anybody has an idea how to get the information of all raster of the subfolders together in one .dbf instead of doing it for each folder individually?
Thanks for your help!
RaphaelR
you can get a list with the tif-rasters from different subfolders with os.walk:
import os
path = "e:\\test\\"
rasters = []
for path,dirs,files in os.walk(path):
    for file in files:
        if file.endswith(".tif") == True:
            rasters.append(str(path) + "\\" + str(file))
JannWendt
This works well but I don't know how to put the this together with the raster information script. As I've written before, I'm more or less completely knew to python...
RaphaelR
import os
import arcpy
# Create table
# Add fields
# Insert values
# get rasters
path = "e:\\test"
rasters = []
    for file in files:
    row = rows.newRow()
    row.name = raster
    rows.insertRow(row)
del row
del rows
JannWendt
Hi rafaelr,
thanks for your support. Now I get the following problem when I run the script:
  File "W:\Organisation\10013 Aktualisierung der Luftbilddatenbank in Bezug auf Georeferenzierung\Daten\georeference_in_attribute_table_new.py", line 31, in <module>
Here is the script I'm using:
import os
import arcpy
env.workspace = "C:/Data"
# Create table
if arcpy.Exists("C:/Data/Test.dbf"):
    arcpy.Delete_management("C:/Data/Test.dbf")
table = arcpy.CreateTable_management("C:/Data", "Test.dbf")
# Add fields
# Insert values
rows = arcpy.InsertCursor("C:/Data/Test.dbf")
# get rasters
path = "C:/data"
rasters = []
    for file in files:
        if file.endswith(".ecw") == True:
            rasters.append(str(path) + "/" + str(file))
    row = rows.newRow()
    row.name = raster
    rows.insertRow(row)
del row
del rows
Do you (or anybody else) have an idea what to do?
Thanks!
Jann
curtvprice
GetRasterProperties returns a result object. See the [post=238595]top of this thread[/post] for how to convert that into a value you can write to a field.
