Publishing to a Group on Enterprise 11.1
127
a week ago
BrandonMcAlister
Hey everyone,
I have a script that creates a feature class then publishes the new feature layer to our enterprise portal and overwrites the layer currently published. Everything works as intended except for publishing the layer to the intended group, it only publishes to owner level sharing. I am able to publish it directly to folders under my name. The group ID I am using it coming from the url for the intended group I have used several iterations of the number string found in the url but have been unsuccessful.
I have used the first code sample under this url. https://pro.arcgis.com/en/pro-app/latest/arcpy/sharing/featuresharingdraft-class.htm#GUID-2B3FAB95-4...
I am just using the wrong group id or am I missing something else?
#read draft file
docs = DOM.parse(sddraftpath)
key_list = docs.getElementsByTagName('Key')
value_list = docs.getElementsByTagName('Value')
#Sharing level
Share_Organization = "false"
Share_Everyone = "false"
Share_Group = "true"
#Sharing to Deed Notice Inspection Tool Group
GroupID = "a49bff8206a1412991219a39ae4067ed"
#write values
for i in range(key_list.length):
if key_list[i].firstChild.nodeValue == "PackageUnderMyOrg":
value_list[i].firstChild.nodeValue = Share_Organization
if key_list[i].firstChild.nodeValue == "PackageIsPublic":
value_list[i].firstChild.nodeValue = Share_Everyone
if key_list[i].firstChild.nodeValue == "PackageShareGroups":
value_list[i].firstChild.nodeValue = Share_Group
if Share_Group == "true" and key_list[i].firstChild.nodeValue == "PackageGroupIDs":
value_list[i].firstChild.nodeValue = GroupID
Brandon
BrandonMcAlister
Being made a group manager solved the issue
Brandon
BrandonMcAlister
Brandon
