I am trying to write a Python script to publish a hosted feature service from selected layers in a map, which is called from my .NET ArcGIS Pro add-in.
If I do not specify any layers from the map to publish (publish all layers), then the service gets published successfully. However, if I do try to specify certain layers to get published, then I receive this error:
File "<string>", line 79, in execute
File "c:\program files\arcgis\pro\Resources\arcpy\arcpy\sharing.py", line 23, in exportToSDDraft
return _convertArcObjectToPythonObject(self._arc_object.exportToSDDraft(out_sddraft, self))
ValueError: Project does not exist or is inaccessible.
Failed to execute (PublishHostedFeatureService).
Here is my code, which is failing on the last line:
current_project = arcpy.mp.ArcGISProject("CURRENT")
current_map = current_project.activeMap
layer_list = []
for layer_name in layer_names:
layers = current_map.listLayers(layer_name)
if len(layers) > 0:
layer_list.append(layers[0])
sharing_draft = current_map.getWebLayerSharingDraft("HOSTING_SERVER", "FEATURE", service_name, layer_list)
sharing_draft.exportToSDDraft(sddraft_output_filename)
Am I doing something wrong with how I am passing the layer information to getWebLayerSharingDraft()?
