Project shapefile returns blank output
3442
01-09-2014 10:00 AM
JasonTaylor
Pretty simple here, hopefully the solution is obvious to the community.
1. make event layer
2. export event layer to shapefile
3. re-project shapefile
InterpolationCSV = "path-to-csv"
XCoord = "Long"
YCoord = "Lat"
ZValue = "Result"
WorkingDirectory = "path-to-wd"
spRefWGS84 = "path-to-prj"
spRefSPN = "path-to-prj"
arcpy.MakeXYEventLayer_management(InterpolationCSV, XCoord, YCoord, "outXY_Layer", spRefWGS84)
arcpy.FeatureClassToFeatureClass_conversion("outXY_Layer", WorkingDirectory, "processpoints.shp")
arcpy.Project_management(WorkingDirectory + "processpoints.shp", WorkingDirectory + "processpoints2.shp", spRefSPN)
This yields a blank output for processpoints2.shp, no matter where I run it, without error.
Any suggestions would be appreciated.
MattSayler
And the first shapefile turns out ok?
JasonTaylor
Yes, the first shapefile works just fine. I'm certain the problem is in the project tool. I'm currently using ogr2ogr as an alternative but it's a messy solution.
JasonTaylor
ogr2ogr isn't that bad after all! If anyone else is having difficulty using the project tool in arcpy than I would recommend calling ogr2ogr from subprocess.call(). gdal isn't in my path so I need to call it using the full path to the executable. Here is a post on how to do to the conversion:
http://www.mercatorgeosystems.com/blog-articles/2008/05/30/using-ogr2ogr-to-re-project-a-shape-file/
easy, fast, straightforward and free!
markdenil
Do you have trailing slashes or back slashes in your WorkingDirectory variable string?
It is surely not really "path-to-wd"...
It is best to avoid them. There are a number of ways to do that.
I usually just explicitly include them inside the string,
even when I am connatenating two or more path strings
for example:
path = r"D:\GIS_Utilities\Tasks\WebProductsImage"   # mxd & gdb path
mxdName = "web_chart_6.mxd"                 # mxd name
theMXD = r"%s\mxd\%s" % (path, mxdName)     # mxd full path
mxd = arcpy.mapping.MapDocument(theMXD)     # mxd object
There are various reasons I do this,
ansd there are more elenet ways to do it.
but the important one here is that there
are no \ or / or \\ at the end of any string.
for a start, try passing explicit path\shapefile strings to the project tool.
Oh, and USE THE CODE FORMATING BUTTON when inserting code in a forum post.
