progressor bar occasionally freezes in arcpy
962
12-30-2024 02:23 AM
JAYAKUMARKUMAR
I am using the following code to process datasets and feature classes from a source geodatabase and apply edits to a destination SDE feature class using arcpy.da.Editor
The progressor bar occasionally freezes or doesn't update correctly during the dataset and feature class processing, which makes it hard to monitor the progress of the script.
SumitMishra_016
Hi @JAYAKUMARKUMAR
The arcpy.SetProgressorPosition() is called after each processed feature class, avoiding freezing or incorrect updates.
Please try like this in your script:
# Set the progressor
arcpy.SetProgressor("step", "Copying shapefiles to geodatabase...",
                    0, fc_count, 1)
# Create a file gdb to contain new feature classes
arcpy.CreateFileGDB_management(arcpy.env.workspace, "fgdb.gdb")
# For each shapefile, copy to a file geodatabase
for shp in fcs:
    # Trim the '.shp' extension
    fc = os.path.splitext(shp)[0]
    # Update the progressor label for current shapefile
    arcpy.SetProgressorLabel("Loading {0}...".format(shp))
    # Copy the data
    arcpy.CopyFeatures_management(shp, os.path.join("fgdb.gdb", fc))
    # Update the progressor position
arcpy.ResetProgressor()
https://pro.arcgis.com/en/pro-app/latest/arcpy/functions/resetprogressor.htm
SumitMishra_016
Hi @JAYAKUMARKUMAR
                    0, fc_count, 1)
for shp in fcs:
    # Copy the data
