Problems with symbology on arcpy.mapping
2460
03-01-2013 07:27 AM
LeticiaNascimento
I have a layer that I added on a mxd through arcpy. However, the symbologyTipe is comming as "OTHER" and I need it to take the symbology as a UNIQUE CLASS. I can't change it and I tryed the UpdateLayer, but nothing happens to my layer. I tryed both in my script and following it on ArcMap.
I also tryed "arcpy.ApplySymbologyFromLayer_management" but it didn't work either.
Does someone knows how to do this?
Thanks!
JeffBarrette
The only way to change a symbology type in arcpy is via update layer.  Can you tell us more about the layer that is failing and the code you are using?
Jeff
LeticiaNascimento
Hello, Jeff!
My code is something like this:
import arcpy.mapping as MP
lyrboias = MP.Layer("c:/GIS_tutorial/SHP/BOIAS_PAC.shp")
lyrboias.name = "Boias"
molde_boias = MP.Layer("c:/GIS/Boias_molde.lyr")
MP.AddLayer(df, lyrboias, "TOP")
updateLayer = MP.ListLayers(mxd, "Boias", df)[0]
MP.UpdateLayer(df, updateLayer, molde_boias, False)
However, I noticed that it is, in fact, updating the "molde_boias". The problem is: in my shape called lyrboias I have an item in the attribute table called "Tipo". I need it to classify the SHP in the two classes I have inside the "Tipo" attribute and collered it with green and red.
Thank you for your help!
Letícia
