problems with layer.findAndReplaceWorkspacePath
2687
05-11-2012 10:34 AM
JoshuaChan
I have a bunch of .lyr files that point to a directory that's been moved.
I'm trying to programmatically re-link them to the new location (hopefully to a UNC location like \\server\folder instead of W:\folder)
so my code looks like this:
import arcpy, sys, os, fnmatch
dir = sys.argv[1]   # directory to search
old = sys.argv[2]   # old feature class path/name to replace
new = sys.argv[3]   # new feature class path/name
# go to the directory and get a list of the files
filelist = os.listdir(dir)
# get that file list and for each name....
for filename in filelist:
    # look for any .lyr files
    if fnmatch.fnmatch(filename, '*.lyr'):
        arcpy.AddMessage(filename + " is a layer file")
        # create a layer object from the .lyr file
        lyrfile = arcpy.mapping.Layer(dir + '\\' + filename)
        arcpy.AddMessage(filename + " is now a layer object")
        arcpy.AddMessage(old)
        arcpy.AddMessage(new)
        lyrfile.findAndReplaceWorkspacePath(old, new)
        arcpy.AddMessage("fixed data source")
arcpy.AddMessage("finito!!!")
del filename, filelist, dir, old, new, lyrfile
but when I run it - I get messages saying that something is happenning (all my addMessages). But when it comes to actually re-mapping my datasource, well, nothing happens. When I re-add the .lyr files to my mxd and check the data source, it doesn't change. It's still the old datasource.
any help???
JoshuaChan
looks like I forgot to save
lyrfile.save()
any help???
JoshuaChan
Is there any difference when working with shapefiles? So far my script doesn't seem to like shapefiles.
(changing from C:\folder\shapefile.shp to \\server\folder\shapefile.shp)
lyrfile.save()
JeffBarrette
This script works fine when run from IDLE (or from the Python window):
import arcpy
layer1 = arcpy.mapping.Layer(r"C:\Temp\NE_States.lyr")
layer1.findAndReplaceWorkspacePath(r"C:\Temp", r"\\JBarrette\Temp")
layer1.saveACopy(r"C:\Temp\NE_States2.lyr")
print layer1.dataSource
>>\\Jbarrette\Temp\NE_Lakes.shp
Are you attempting to change the dataset name in any way?  FindAndReplaceWorkspacePath only works on the workspace path.
Jeff
JoshuaChan
no I was running the script from arctoolbox
I thought I had this figured out but now when I run it ArcGIS crashes. Doesn't matter if it's ArcCatalog or ArcMap.
import arcpy
Jeff
