I have written a script which runs fine inside of ArcMap in the Python-Window but does not outside of ArcMap in PythonWin.
My intention for the last step was to delete all the files I created except of the Result txt-file.
But if I run the script in PythonWin there seems to be some problems with the license of Spatial Statistic or/and with the fparameters within the arcpy functions.
The script looks like this (sorry, the explanation parts and the file names are partly in german):
import os, arcpy
Pfad="C:/Users/behr/Desktop/DAC_MD/"
Pfad1="C:/Users/behr/Desktop/DAC_MD/Delete/"
PfadTxt="C:/Users/behr/Desktop/DAC_MD/01_MD_HH_klein/"
# Festlegen ob das Ergebnis Hydr. Höhen oder Salzgehalt ist
Sz="HH"
TextDateienListe = os.listdir(PfadTxt)
for Datei in TextDateienListe:
#Datei=TextDateienListe[1]
b = os.path.splitext(Datei)
# XY-Event Layer erstellen // Input: txt-Datei //Output: Layer mit Variable EventLayerName
EventLayerName= b[0] + "_Layer"
arcpy.MakeXYEventLayer_management(PfadTxt+Datei,"x","y",EventLayerName,"PROJCS['ETRS_1989_UTM_Zone_33N',GEOGCS['GCS_ETRS_1989',DATUM['D_ETRS_1989',SPHEROID['GRS_1980',6378137.0,298.257222101]],PRIMEM['Greenwich',0.0],UNIT['Degree',0.0174532925199433]],PROJECTION['Transverse_Mercator'],PARAMETER['False_Easting',500000.0],PARAMETER['False_Northing',0.0],PARAMETER['Central_Meridian',15.0],PARAMETER['Scale_Factor',0.9996],PARAMETER['Latitude_Of_Origin',0.0],UNIT['Meter',1.0]];-5120900 -9998100 10000;-100000 10000;-100000 10000;0,001;0,001;0,001;IsHighPrecision","HH")
# Kriging // Output: Raster rXXX
arcpy.gp.Kriging_sa(EventLayerName,"HH",Pfad1+"r" + b[0],"Spherical 15,717080","15,7170800000001","VARIABLE 12","#")
# Hydrotopdatei kopieren zum späteren Einlesen der gemittelten Werte
arcpy.CopyFeatures_management(Pfad+"HydrotMD.shp",Pfad1+"Hydrotop" + b[0]+".shp","#","0","0","0")
#Zonale Statistiken: Mittelwerte bilden für Hydrotop und Raster und in Tabelle ausspucken
arcpy.gp.ZonalStatisticsAsTable_sa(Pfad1+"Hydrotop" + b[0]+".shp","ID_COMTESS",Pfad1+"r" + b[0],Pfad1+ "t"+b[0],"DATA","MEAN")
# Tabellenfeld per ID_COMTESS-Feld in die hydrotop-Datei integrieren
arcpy.JoinField_management(Pfad1+"Hydrotop" + b[0]+".shp","ID_COMTESS",Pfad1+ "t"+b[0],"ID_COMTESS","MEAN")
#Exportieren der ID mit dem dazugehörigen Mittelwert in eine Textdatei
arcpy.ExportXYv_stats(Pfad1+"Hydrotop" + b[0]+".shp","ID_COMTESS;MEAN","SPACE",Pfad + "Results/01_MD_"+Sz+"_"+b[0],"ADD_FIELD_NAMES")
| arcpy.CopyFeatures_management(Pfad+"HydrotMD.shp",Pfad1+"Hydrotop" + b[0]+".shp","#","0","0","0") |
| #Zonale Statistiken: Mittelwerte bilden für Hydrotop und Raster und in Tabelle ausspucken | |
| arcpy.gp.ZonalStatisticsAsTable_sa(Pfad1+"Hydrotop" + b[0]+".shp","ID_COMTESS",Pfad1+"r" + b[0],Pfad1+ "t"+b[0],"DATA","MEAN") | |
| # Tabellenfeld per ID_COMTESS-Feld in die hydrotop-Datei integrieren | |
| arcpy.JoinField_management(Pfad1+"Hydrotop" + b[0]+".shp","ID_COMTESS",Pfad1+ "t"+b[0],"ID_COMTESS","MEAN") |
| #Exportieren der ID mit dem dazugehörigen Mittelwert in eine Textdat | |
| arcpy.ExportXYv_stats(Pfad1+"Hydrotop" + b[0]+".shp","ID_COMTESS;MEAN","SPACE",Pfad + "Results/01_MD_"+Sz+"_"+b[0],"ADD_FIELD_NAMES") |
The errors occuring are:
1.
ExecuteError: Errors during execution . Parameters are invalid .
ERROR 000824: The tool is not licensed .
Error executing ( kriging ) .
So my question is: is it not possible to run spatial statistic stuff outside of arcmap because of the license?
And could the first problem be, that I cant't use the parameters like "HH" as the row-definition in the attribute table outside of ArcMap?
Thanks in advance!
Leonore
Spatial Statistik müsste schon funktionieren. Wahrscheinlich mußt du im script die extension dazu auschecken? SA?
Sorry, it seems I couldn't load the file exactly: The lines 42 till 80 are indented, too, in the original script.
Hallo Johannes,
vielen Dank, das war die Lösung! Doch so einfach ![]()
eine Frage habe ich noch:
Ich wollte unten jetzt einfach noch folgendes einfügen:
| #Löschen der unnötigen Files | |
| for filename in os.listdir(Pfad+ "Delete/"): | |
| os.remove(os.path.join(Pfad+ "Delete/", filename)) |
um damit die Daten aus dem Delete-Ordner, in dem ich alle Zwischenschritte abgespeichert habe, bequem zu löschen.
Da erscheint aber folgender Error:
WindowsError: [Error 5] Zugriff verweigert: 'C:/Users/behr/Desktop/DAC_MD/Delete/info'
Liegt das dann an den Windows-Rechten? Kann ich die vielleicht irgendwie umgehen?
Vielen Dank schonmal,
Leonore
Die Fehlermeldung deutet schon auf ein Rechteproblem hin. Ich würde die Daten einfach woanders speichern?
Umgehen geht glaube ich nicht, zumindest ist mir da nichts bekannt.
OK, dann werde ich das halt einfach per Hand löschen müssen.
Danke für die Lösungshilfe!
I don't see where you are checking out/in your Spatial Analyst extension.
### see if spatial analyst extension is available for use
availability = arcpy.CheckExtension("Spatial")
if availability == "Available":
arcpy.CheckOutExtension("Spatial")
arcpy.AddMessage("SA Ext checked out")
else:
arcpy.AddError("%s extension is not available (%s)"%("Spatial Analyst Extension",availability))
arcpy.AddError("Please ask someone who has it checked out but not using to turn off the extension")
return
#do your processing with SA
# check the sa extension back in
arcpy.CheckInExtension("Spatial")
This was already proposed - in German so you haven't had the chance to read it - or do u speak german? 🙂
Actually she has got some problems with deleting files with os.remove according to access authority on "C:/Users/behr/Desktop". No idea why she has to saves the things there? But maybe you have a idea for a solution?
