Problem with Calculate Geometry Attributes
1596
10-30-2020 07:14 AM
anyry
Hello,
I have a problem with Calculate Geometry Attributes. I have shp of point and I want Point x-coordinate and Point y-coordinate of them. I need values in decimal degrees in ETRS_1989_UTM_Zone_33N coordinate system. But if I will set Coordinate format as Decimal Degrees, it will give me values in WGS 84 and if I set coordinate system to  ETRS_1989_UTM_Zone_33N it will give values in metres. Can you help me with solution? I really need help.
Thanks
Aneta
Luke_Pinner
MVP Regular Contributor
ETRS89 / UTM zone 33N is a projected coordinate system and uses metres as the horizontal units.  If you want decimal degrees, you need to use a geographic coordinate system (like you did with WGS84).  Have you tried selecting the ETRS89 geographic coordinate system?
