Problem Removing Join with 32 bit Python 2.7
9999
14
08-14-2013 08:44 AM
MichaelVolz
Esteemed Contributor
To All Python Programmers:
I had a python script to update a feature class in a personal geodatabase using a join to a table view which works fine at 10.0 with Python 2.6.  I am now trying to run this script on a 64 bit Windows 2008 Server using the 32 bit version of python 2.7 since personal geodatabases are not accessible with 64 bit python.
I am crashing the script when removing a join with the following error message
"ERROR 000800: The value is not a member of  l ALIASES."
Has anyone ever encountered this error message and been able to resolve the issue?
Any help or hints in regard to this issue are greatly appreciated.  Thanks.
MichaelVolz
Rhett:
Does the table (or table view) need to be in the same geodatabase when the join is created in order for the RemoveJoin_management process to work with the join_name parameter supplied?
The reason I ask is because instead of creating a table view in the file geodatabase where the SDE feature class is extracted to, I just used the SDE table to join to the feature class in the file geodatabase.  Unfortunately, I still receive an error where "The value is not a member of l ALIASES".
MichelleBoivin
It is now 2015 and I am unfortunately having this same issue....I have a script that was created in Python 2.6 for 10.0 that runs, but are, yes I know, a little late, upgrading to 10.1 prior to going to 10.3 - moving right now is not an option....anyhow, a RemoveJoin works well with a shapefile, however there is one join in the script from the consultant that sets a join to a table in SDE. I have tried the same workarounds and still cannot get the RemoveJoin to work. Did anyone ever from up with a fix for this? Especially while working in SDE?
BlakeTerhune
If you're using a table in SDE (instead of a feature class), are you creating a table view instead of a feature layer?
Also, make sure you're referencing the correct table view for the remove.
ArcGIS Help 10.1 - Remove Join (Data Management)
Could you also try rewriting just a simple add join, remove join based on the Esri help example to see if you're doing it right. Once you get something working, start adding in the rest of your code and see where it breaks. Maybe post a sample here so we can review it.
MichelleBoivin
The consultant did not write the join table as such, only the feature class that the table was to be joined to. I did test two different ways…
I created a small model that made a feature layer as well as a table view, created the join, and then tried to remove the join. In addition, I exported the script out to test it, just to be on the safe side. The Remove Join still failed, and instead of giving an “800” error, it gives the infamous 999999 error (see below).
BlakeTerhune
I just tried the same thing in a File Geodatabase and it worked. Maybe try leaving that optional "Join" field in Remove Join blank.
However, I was not using GlobalID as a key field. Is there something else you could use to test with just to see if you can get a model that works?
