Problem in Deleting Feature Classes in Geo Database
2585
04-16-2014 09:02 PM
H_A_D_Padmasiri
Dear Sir
I wrote a python programme to delete feature classes in a Geo database.
it works, But feature classes are not delete. What is the reason ? and How to correct it?
Padmasiri
import arcpy
from arcpy import env
env.workspace = r"J:\Gampaha\51027202\CM51027202.gdb\CM51027202"
FClass_List = ["CNT_Anno", "CNT_Anno_CD", "CNT_PT", "PCL_CT1"]
for FClass in FClass_List:
arcpy.DeleteFeatures_management(FClass)
<Result 'J:\\Gampaha\\51027202\\CM51027202.gdb\\CM51027202\\CNT_Anno'>
<Result 'J:\\Gampaha\\51027202\\CM51027202.gdb\\CM51027202\\CNT_Anno_CD'>
<Result 'J:\\Gampaha\\51027202\\CM51027202.gdb\\CM51027202\\CNT_PT'>
<Result 'J:\\Gampaha\\51027202\\CM51027202.gdb\\CM51027202\\PCL_CT1'>
DouglasSands
Hi Padmasiri,
The problem is that the delete features tool removes the features from a feature class or layer (empties it). This is why the result is the name of the feature class you put into the tool. Because you want to delete the dataset completely, you want to use the delete tool:
import arcpy
    arcpy.Delete_management(FClass)
Also, if you wrap scripts in code tags when posting, it will display a bit cleaner (like the above). Hope this helps!
- Doug
