Problem importing stats from scipy with new Arc10.1 install
1422
10-26-2013 03:33 PM
JacobDeAngelo
Hi All,
I have a new machine with a fresh install of Arc10.1.  My script can import scipy, but when I try
from scipy import stats
I get:
  File "C:\ArcProjects\BasinLoop3_All6.py", line 13, in <module>
  File "C:\Python27\ArcGISx6410.1\lib\site-packages\scipy\stats\__init__.py", line 324, in <module>
    from .stats import *
  File "C:\Python27\ArcGISx6410.1\lib\site-packages\scipy\stats\stats.py", line 242, in <module>
    import scipy.special as special
  File "C:\Python27\ArcGISx6410.1\lib\site-packages\scipy\special\__init__.py", line 531, in <module>
    from ._ufuncs import *
ImportError: DLL load failed: The specified module could not be found.
I have tried several scipy installs and I get the same result with each:
scipy-0.13.0-win32-superpack-python2.7.exe
scipy-0.13.0.win-amd64-py2.7.exe
scipy-0.11.0-win32-superpack-python2.7.exe
I figure it has to do do with some incompatibility with the different numpy, scipy versions and the version of python that came with Arc10.1 (py2.7).  Also you can see from my error that my script (ran in IDLE) that it is trying to run this with 64bit python.  Can someone help me sort out what's going on here?
Thanks...
StacyRendall1
You need the 64-bit version (to match your Python), and I think it needs to be an older one like 0.10 or 0.11
64-bit versions that old aren't available from the normal Scipy page, but you can google "64 bit scipy" and should be able to find some compiled binaries...
