Pro:How to check if domain exists, if not, do something else skip
8656
13
06-10-2018 11:35 AM
ThomasColson
I'm attempting to use py to check if a domain exists, if not, create it, else do nothing. After consulting How do I check if a domain already exists? , arcgis 10.0 - Using arcpy.Exists for domains? - Geographic Information Systems Stack Exchange , and esri geodatabase - Checking if domain already exists using ArcPy? - Geographic Information Systems S... I came up with the attached code. If neither domain exists, it fails with:
Start Time: Sunday, June 10, 2018 2:28:13 PM
Running script Add Extended Core Fields...
Failed script Add Extended Core Fields...
 File "C:\Temp\PRO_FOLDER_STRUCTURE\EXTENDED_CORE_FIELDS.py", line 24, in <module>
 arcpy.CreateDomain_management(gdb_name, "DOM_YES_NO_UNK_NPS2016", "Is the feature physically observable", "TEXT", "CODED")
 File "c:\program files\arcgis\pro\Resources\arcpy\arcpy\management.py", line 1332, in CreateDomain
 raise e
 File "c:\program files\arcgis\pro\Resources\arcpy\arcpy\management.py", line 1329, in CreateDomain
 retval = convertArcObjectToPythonObject(gp.CreateDomain_management(*gp_fixargs((in_workspace, domain_name, domain_description, field_type, domain_type, split_policy, merge_policy), True)))
 File "c:\program files\arcgis\pro\Resources\arcpy\arcpy\geoprocessing\_base.py", line 496, in <lambda>
 return lambda *args: val(*gp_fixargs(args, True))
arcgisscripting.ExecuteError: Failed to execute. Parameters are not valid.
 ERROR 000192: Invalid value for Domain Name
Failed to execute (CreateDomain).
 Failed to execute (AddExtendedCoreFields).
Failed at Sunday, June 10, 2018 2:28:14 PM (Elapsed Time: 1.52 seconds)‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
However it creates the domain!
If I run it again knowing the domain exists, same error message.
import os
import errno
import arcpy
#Get user input
gdb_name = arcpy.GetParameterAsText(0)
fc_name = arcpy.GetParameterAsText(1)
isOBSERVABLEchecked = arcpy.GetParameterAsText(2)
isISEXTANTchecked = arcpy.GetParameterAsText(3)
#Create the Optional OBSERVABLE domain
if str(isOBSERVABLEchecked) == 'true':
        existingDomains = arcpy.da.ListDomains(gdb_name)
        isthere = False
        for domain in existingDomains:
                if domain.name == 'DOM_YES_NO_UNK_NPS2016':
                        isthere = True
                        break
                if isthere == False:
                        YESNODict = {"Unknown":"Unknown", "Yes": "Yes", "No": "No"}
                        for code in YESNODict:
                                arcpy.AddCodedValueToDomain_management(gdb_name, "DOM_YES_NO_UNK_NPS2016", code, YESNODict[code])
                else:
                        arcpy.AddMessage("DOM_YES_NO_UNK_NPS2016 already exists")
#Create the Optional ISEXTANT domain
if str(isISEXTANTchecked) == 'true':
        isthere = False
                        isthere = True
                        break
                                arcpy.CreateDomain_management(gdb_name, "DOM_ISEXTANT_NPS2016", "Indicates feature or features that are no longer in existence or partially in existence.", "TEXT", "CODED")
                                ISEXTANTDict = {"Unknown":"Unknown", "True": "True", "False": "False", "Partial": "Partial", "Other": "Other"}
                                for code in ISEXTANTDict:
                                        arcpy.AddCodedValueToDomain_management(gdb_name, "DOM_ISEXTANT_NPS2016", code, ISEXTANTDict[code])
                else:
                        arcpy.AddMessage("DOM_ISEXTANT_NPS2016 already exists")‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
As best as I can tell, I have an illegal loop condition that keeps trying to create the first domain whether it exists or not, and the failure stems from the domain name already exists.
ThomasColson
So with some modification to your sample to make it work in Pro, I get the following regardless if the domain exists or not.
Start Time: Thursday, June 14, 2018 8:58:08 AM
Running script Test...
Completed script Test...
Succeeded at Thursday, June 14, 2018 8:58:08 AM (Elapsed Time: 0.13 seconds
RandyBurton
Try this:
found = False
        found = True
if found:
    print "Domain exists"
else:
    print "Domain does not exist"
DanPatterson_Retired
Randy to keep it in the loop...
existingDomains = [0, 1, 1, 0, 1, 1, 1]  # fake domain names
    if domain == 1:
        found = True
        print("Domain exists")
    else:
        found = False
        print("Domain does not exist")
Domain exists
Domain exists
Domain exists
Domain exists
Domain exists‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
and with python 3.6+ you can do some really cool stuff with f-strings
d = "\n".join([[f"{domain} exists", f"{domain} Missing"][domain==1] for domain in existingDomains])
print(d)
0 exists
1 Missing
1 Missing
0 exists
1 Missing
1 Missing
1 Missing
ThomasColson
Randy and Dan, you were both on to something with the "list" idea, instead of looping through each domain in the GDB.....just make a list and check for membership in the list!
Here's what ultimately worked:
domain_names = [i.name for i in existingDomains]
if 'DOM_YES_NO_UNK_NPS2016' in domain_names :
        print("DOM_YES_NO_UNK_NPS2016 already exists")
else:
        print("creating domain")
which results in:
== RESTART: C:\temp\Pro_Folder_Structure\EXTENDED_CORE_FIELDS_20180614_A.py ==
creating domain
