Preserve GlobalIDs with python truncate append
1800
07-21-2023 07:59 AM
kapalczynski
I have a script that I am trying to truncate and append features from one DB to another... DEV to TEST
The truncate and Append works but I need to preserve the GlobalIDs.
I read that this is what I need to define but the GlobalIDs on the out FC are different than the original ... Again these are in different DBs but same FC name
Note this is an Enterprise Geodatabase....
Any thoughts?
# Set the preserveGlobalIds environment to True
arcpy.env.preserveGlobalIds = True
# --Import arcpy module--------------------------------------------------------------------------------------
import arcpy
layers_to_Modify = {
"Database Connections\\GIS_DEV@gis_data.sde\\GIS_DATA.AAAA": "Database Connections\\GIS_TEST@gis_data.sde\\GIS_DATA.AAAA"
def truncateAppendData():
    print("Starting to Replace the data")
    for layer in layers_to_Modify.keys():
        fromRelationship = layer
        toRelationship = layers_to_Modify[layer]
        try:
            arcpy.TruncateTable_management(toRelationship)
            arcpy.Append_management(fromRelationship, toRelationship, "NO_TEST")
            print("-- append Successful...".format())
        except Exception:
            # Handle errors accordingly...this is generic
            tb = sys.exc_info()[2]
            tb_info = traceback.format_tb(tb)[0]
            # Python 3.x
            #pymsg = f'PYTHON ERRORS:\n\tTraceback info:\t{tb_info}\n\tError Info:\t{str(sys.exc_info()[1])}\n'
            #msgs = f'ArcPy ERRORS:\t{arcpy.GetMessages(2)}\n'
            # Python 2.7
            pymsg = 'PYTHON ERRORS:\n\tTraceback info:\t{tb_info}\n\tError Info:\t{str(sys.exc_info()[1])}\n'
            msgs = 'ArcPy ERRORS:\t{arcpy.GetMessages(2)}\n'
            print(pymsg)
            print(msgs)
            print.error("-- PYTHON ERRORS:\n\tTraceback info:\t{tb_info}\n\tError Info:\t{str(sys.exc_info()[1])}\n".format())
            print.error("-- ArcPy ERRORS:\t{arcpy.GetMessages(2)}\n".format())
if __name__ == '__main__':
    ## Truncate and Append Data
kapalczynski
Please REFER to the original post... that code works ....
kapalczynski
UGGGGGGG my mistake... I was looking at the wrong Feature Class in the Destination... duh.... That code is working fine....
Cheers
kapalczynski
