Populate new field based on max value
2093
02-27-2019 03:56 AM
NikolajGrønholdt
I am working with election data, with each row representing a district and each column represent a party. The columns have a percentage value for each party, in relation to total amount of votes in the given district. I have attached a screenshot of
my table.
Is there some way, using arcpy, that I can populate a new field with the column name of the winning party, as well as another field with the winning percentage?
An example could be the first row, where the winning party is 'A. Socialdemokratiet', with a percentage of 28,8. These two values would then be written to two new columns, say 'Winner: A. Socialdemokratiet' and 'Winner_share: 28,8'
RandyBurton
You might try something like:
import arcpy
fc = r"C:\path\to\file.gdb\feature"
# add field (may want to check if they exist first)
arcpy.AddField_management(fc, "winner", "TEXT", "", "", 50,
                          "winner", "NULLABLE")
arcpy.AddField_management(fc, "percent", "DOUBLE", "", "", "",
                          "percent", "NULLABLE")
# list of fields with votes, and for winner and winning percent
fields = [ 'socialdemo', 'radikale', 'konservative', 'socialistisk', 'liberal', 'winner', 'percent' ]
with arcpy.da.UpdateCursor(fc, fields) as cursor:
    for row in cursor:
        votes = row[:5] # fields with vote counts or percentages
        # get maximum vote / percent
        winTotal = max(votes)
        # get winner / party
        winner = fields[votes.index(max(votes))]
        # other options if needed
        # # if votes, you can sum them
        # vTotal = sum(votes)
        # # and calculate percentage
        # percent = float(winTotal)/vTotal
        row[5] = winner   # party
        row[6] = winTotal # percent
        cursor.updateRow(row)‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
Hope this helps.
RandyBurton
import arcpy
    for row in cursor:
Hope this helps.
NikolajGrønholdt
That worked just as intended. Thank you for the help. For some reason, I couldn't come up with the votes.index part.
