polyline to polygon (comparison tool and own code)
6237
11
05-22-2017 12:03 AM
SibghatUllah1
I am trying to convert a ploy line feature class to polygon without using Arc info Advanced Licence.The code i am using runs fine and converts polyline to polygon. I have run the "tool feature to polygon" to make a comparison.My code is not converting all lines to polygon(See Screenshot).I have also attached my code.please guide me to get the same results.
Polyline :Red(to be converted)
Mycode:Brown
Feature to polygon: Blue
import arcpy
import arcpy
import os
from arcpy import env
env.overwriteOutput = True
starttime = time.time()
localtime = time.asctime( time.localtime(time.time()) )
# Create a value table that will hold the input feature classes for Merge
mxd=arcpy.mapping.MapDocument("CURRENT")
df = arcpy.mapping.ListDataFrames(mxd, "")[0]
for lyr in arcpy.mapping.ListLayers(mxd,"",df):
    if not lyr.isGroupLayer:
        arcpy.AddMessage(lyr.name)
        if "Export" in lyr.name :
            break
desc = arcpy.Describe(lyr)
shapefieldname = desc.ShapeFieldName
outPolys=r'C:\RAECGIStoCAD\test.gdb\temp'
arcpy.DeleteFeatures_management(r'C:\RAECGIStoCAD\test.gdb\temp')
joinoutput=r'C:\RAECGIStoCAD\test.gdb\join'
spatialRef = arcpy.Describe(lyr).spatialReference
featureList = []
#array = arcpy.Array()
cursor = arcpy.da.InsertCursor(outPolys, ['SHAPE@'])
rows = arcpy.SearchCursor(lyr)
for row in rows:
    # Create the geometry object
    feat = row.getValue(shapefieldname)
    #print "Feature %i: " % row.getValue(desc.OIDFieldName)
    partnum = 0
    part_list = []
    # Step through each part of the feature
    for part in feat:
        polygonArray = arcpy.Array()
        for pnt in feat.getPart(partnum):
            if pnt:
                # Add to list
                part_list.append([pnt.X, pnt.Y])
                polygonArray.add(arcpy.Point(pnt.X,pnt.Y))
                partnum += 1
    print partnum
    print part_list
    polygon = arcpy.Polygon(polygonArray)
    featureList.append(polygon)
    cursor.insertRow([polygon])
del cursor
endtime = time.time()
totaltime = endtime-starttime
print "\nScript took " + str(totaltime/60) + " minutes to run"
Tags (1)
SibghatUllah1
Dear Luke,
Actually my client dont have advanced license.yes i was storing only vertices coordinates and drawing a new polygon. Is it possible to construct polygon using python script? any suggestion
https://community.esri.com/external-link.jspa?url=http%3A%2F%2Fdesktop.arcgis.com%2Fen%2Farcmap%2F10...
LukeWebb
I am unable to come up with a decent algorithym.... and I love a challenge!
I feel ESRI have constructed a decent tool, and knowing this, put it behind an advanced license for 'commercial' reasons I would advise looking at the open source tools provided in our other threads, as this is a not a simple task to accomplish.
Unless you have any good ideas of how the algorithm should work I could try to implement
