Polygon from GeoJson to Shp conversion arcpy script is being simplified
4583
01-13-2014 12:51 PM
MattEiben
I'm trying to make a script that converts the GeoJson format into a shapefile.  For the most part, the script in complete, but I'm having an odd issue with the output polygon.
The JSON geometry has a large number of vertices, but ArcMap seem to be GREATLY simplifying the output polygon when arcpy.Polygon(arcpy.Array(point, point, point ...)) happens.
The script I'm using is posted below.  Though note, I left out many of the not relevant parts.
from collections import OrderedDict import arcpy, json, os  arcpy.env.overwriteOutput = True  def createPolygon(data):     """     This function receives a python dictionary representing the JSON array and its geometry     type.  It will create a feature class of that geometry type and add in the features geometry     and attributes (if any).     """      # Create feature class and define as WGS84     outFC = arcpy.CreateFeatureclass_management(outLocation,outName,"POLYGON")     arcpy.DefineProjection_management(outFC, coordinateSystem)          features = data["features"]          # Get a list of fields and add them to the feature class     fields = [key for key, value in features[0]["properties"].iteritems()]          if len(fields) != 0:         # dummyField is used because ArcMap requires at least one non-required field.         arcpy.AddField_management(outFC,"dummyField","TEXT")         arcpy.DeleteField_management(outFC,"Id")         for field in fields:             arcpy.AddField_management(outFC,field,"TEXT")         arcpy.DeleteField_management(outFC,"dummyField")          # Create search cursor     cursor = arcpy.da.InsertCursor(outFC, ["SHAPE@"] + fields)          #Create Arcpy Array to add Polygon verticies too.     array = arcpy.Array()      # Building Polygon     n = 0     for feature in features:          n += 1                  for geom in feature["geometry"]["coordinates"]:             for coords in geom:                 # Adding verticies to array                 array.add(arcpy.Point( float(coords[0]), float(coords[1]) ))                          # Get attributes for insert cursor fields         attributes = [attr for key, attr in feature["properties"].iteritems()]                  # Some debugging prints           print len(array)                            # this reads 150 arcpy.Point objects         print arcpy.Polygon(array).pointCount       # This only reads 15 points, none of which are the original points.  Somehow ArcMap is GREATLY simplifyig this geometry.                  cursor.insertRow([arcpy.Polygon(array)] + attributes)         array.removeAll()          del cursor         jsonFileName = "inputjsonfile.json" shpOutput = "C:\Path\To\Output\Location\polygon.shp"  outLocation = os.path.dirname(shpOutput) outName = os.path.basename(shpOutput)  coordinateSystem = arcpy.SpatialReference(4326)  with open(jsonFileName,"r") as json_file:     data = json.load(json_file, object_pairs_hook=OrderedDict)          # Get geometry type     geomType = data["features"][0]["geometry"]["type"]      if geomType == "Polygon":         createPolygon(data)
The inputs and outputs have been hardcoded for this example, but eventually it will end up as a Python Toolbox
For testing purposes, below is the JSON file I was trying to convert in this example:
{"type": "FeatureCollection", "features": [{"type": "Feature", "properties": {"Id": "0", "NAME": "Untitled Polygon", "DESCR": " ", "FOLDER": " "}, "geometry": {"bbox": [-105.6266922454426, 33.309856365277824, -105.61766863755298, 33.31951402483418], "coordinates": [[["-105.623511", "33.317474"], ["-105.623508", "33.317525"], ["-105.623477", "33.317550"], ["-105.623410", "33.317651"], ["-105.623255", "33.317725"], ["-105.623129", "33.317825"], ["-105.623035", "33.317875"], ["-105.622915", "33.317873"], ["-105.622794", "33.317871"], ["-105.622647", "33.317792"], ["-105.622592", "33.317715"], ["-105.622505", "33.317612"], ["-105.622352", "33.317536"], ["-105.622136", "33.317434"], ["-105.622015", "33.317357"], ["-105.621831", "33.317304"], ["-105.621673", "33.317253"], ["-105.621551", "33.317226"], ["-105.621368", "33.317174"], ["-105.621337", "33.317173"], ["-105.621242", "33.317223"], ["-105.621115", "33.317298"], ["-105.621108", "33.317450"], ["-105.621133", "33.317578"], ["-105.621186", "33.317732"], ["-105.621241", "33.317861"], ["-105.621356", "33.318016"], ["-105.621381", "33.318119"], ["-105.621464", "33.318275"], ["-105.621482", "33.318507"], ["-105.621507", "33.318610"], ["-105.621497", "33.318791"], ["-105.621424", "33.318972"], ["-105.621257", "33.319179"], ["-105.621129", "33.319230"], ["-105.620967", "33.319334"], ["-105.620837", "33.319411"], ["-105.620739", "33.319489"], ["-105.620644", "33.319514"], ["-105.620457", "33.319512"], ["-105.620182", "33.319507"], ["-105.619851", "33.319423"], ["-105.619417", "33.319278"], ["-105.619082", "33.319195"], ["-105.618724", "33.319046"], ["-105.618416", "33.318900"], ["-105.618238", "33.318741"], ["-105.618051", "33.318500"], ["-105.617920", "33.318313"], ["-105.617896", "33.318209"], ["-105.617900", "33.318081"], ["-105.617877", "33.317926"], ["-105.617718", "33.317613"], ["-105.617669", "33.317381"], ["-105.617673", "33.317152"], ["-105.617674", "33.316846"], ["-105.617685", "33.316565"], ["-105.617703", "33.316411"], ["-105.617751", "33.316283"], ["-105.617761", "33.316181"], ["-105.617843", "33.315979"], ["-105.617887", "33.315878"], ["-105.617963", "33.315777"], ["-105.618075", "33.315652"], ["-105.618192", "33.315553"], ["-105.618349", "33.315406"], ["-105.618570", "33.315260"], ["-105.618872", "33.315167"], ["-105.619245", "33.315051"], ["-105.619605", "33.314985"], ["-105.619946", "33.314869"], ["-105.620061", "33.314845"], ["-105.620328", "33.314726"], ["-105.620592", "33.314631"], ["-105.620778", "33.314487"], ["-105.621017", "33.314367"], ["-105.621149", "33.314248"], ["-105.621169", "33.314104"], ["-105.621163", "33.313937"], ["-105.621128", "33.313771"], ["-105.621072", "33.313558"], ["-105.620928", "33.313370"], ["-105.620776", "33.313155"], ["-105.620615", "33.312986"], ["-105.620475", "33.312766"], ["-105.620310", "33.312694"], ["-105.620201", "33.312646"], ["-105.620090", "33.312573"], ["-105.619838", "33.312450"], ["-105.619617", "33.312304"], ["-105.619412", "33.312105"], ["-105.619183", "33.311882"], ["-105.619016", "33.311614"], ["-105.618821", "33.311273"], ["-105.618801", "33.311131"], ["-105.618895", "33.310834"], ["-105.619041", "33.310570"], ["-105.619432", "33.310313"], ["-105.619758", "33.310103"], ["-105.620176", "33.309952"], ["-105.620624", "33.309856"], ["-105.621002", "33.309897"], ["-105.621464", "33.309992"], ["-105.621709", "33.310086"], ["-105.621857", "33.310213"], ["-105.621952", "33.310367"], ["-105.621971", "33.310478"], ["-105.622093", "33.310607"], ["-105.622246", "33.310834"], ["-105.622495", "33.311170"], ["-105.622773", "33.311533"], ["-105.622925", "33.311762"], ["-105.623194", "33.312341"], ["-105.623289", "33.312598"], ["-105.623422", "33.312690"], ["-105.623501", "33.312759"], ["-105.623716", "33.312825"], ["-105.623853", "33.312845"], ["-105.623964", "33.312868"], ["-105.624024", "33.312869"], ["-105.624166", "33.312943"], ["-105.624244", "33.313062"], ["-105.624417", "33.313212"], ["-105.624569", "33.313244"], ["-105.624833", "33.313324"], ["-105.625213", "33.313455"], ["-105.625559", "33.313582"], ["-105.625844", "33.313705"], ["-105.625987", "33.313779"], ["-105.626188", "33.313878"], ["-105.626360", "33.313976"], ["-105.626472", "33.314123"], ["-105.626612", "33.314319"], ["-105.626692", "33.314538"], ["-105.626684", "33.314782"], ["-105.626677", "33.315003"], ["-105.626641", "33.315224"], ["-105.626548", "33.315396"], ["-105.626513", "33.315569"], ["-105.626420", "33.315741"], ["-105.625983", "33.316182"], ["-105.625570", "33.316456"], ["-105.625347", "33.316607"], ["-105.625094", "33.316757"], ["-105.624817", "33.316904"], ["-105.624307", "33.317195"], ["-105.624008", "33.317363"], ["-105.623802", "33.317433"], ["-105.623655", "33.317479"], ["-105.623511", "33.317474"]]], "type": "Polygon"}}]}
Any help is appreciated,
Thanks!
Matt
StacyRendall1
Hi Matt,
If you specify the coordinate system when creating the polygons (lines 51 and 53 of your original code) it appears to work...
        print arcpy.Polygon(array, coordinateSystem).pointCount          cursor.insertRow([arcpy.Polygon(array, coordinateSystem)] + attributes)
Let me know how you get on.
Stacy
StacyRendall1
Hi Matt,
Stacy
MattEiben
That did it!
I didn't see the inputs for the Polygon object:
Polygon (inputs, {spatial_reference}, {has_z}, {has_m})
Putting the spatial reference in there worked like a charm,
Thanks very much!
