Please Help! Calculate Median Value
14094
11
10-11-2013 01:06 PM
Chang-HengYang
Hi all,
Thank you for your time in advance. I tried to update the script (downloaded from Calculate Median Value) from v9.3 to v10.1 and ran the script in the tool. However, V10.1 does not work (v9.3 works). The attached file would show the error message. I also listed my original v10.1 python code. I tried to add the filed_name in arcpy.da.SearchCursor(inputTable, readField). However, it still failed to work. Please let me know if there is any problem with my v10.1 python code.
Hank
v9.3 version python code from Corey Denninger
Script created by Chris Snyder; modified by C. Denninger
# Script resulted from ESRI Forum posts dated 04FEB2010.
# This script is used in a script tool within ArcGIS and calculates
#..the median value of one entire field and posts that single median
#...value to every row in one other entire field.
import sys, arcgisscripting
gp = arcgisscripting.create(9.3)
inputTable = gp.GetParameterAsText(0)
readField = gp.GetParameterAsText(1) #this needs to be a numeric field
writeField = gp.GetParameterAsText(2) #this needs to be a double or float
valueList = []
searchRows = gp.searchcursor(inputTable)
searchRow = searchRows.next()
while searchRow:
   searchRowValue = searchRow.getvalue(readField)
   if searchRowValue == None:
      pass #don't add a null value to the list!
   else:
      valueList.append(searchRowValue)
del searchRow
del searchRows
valueList.sort()
listLength = len(valueList)
if listLength == 0:
   print "Every value was null! Exiting script..."; sys.exit()
elif listLength % 2 == 0: #even, so get the mean of the 2 center values
   medianValue = (valueList[listLength / 2] + valueList[listLength / 2 - 1]) / 2.0
else: #odd, so it's easy!
   medianValue = valueList[listLength / 2]
updateRows = gp.updatecursor(inputTable)
updateRow = updateRows.next()
while updateRow:
   updateRow.setvalue(writeField, medianValue)
   updateRows.UpdateRow(updateRow)
del updateRow
del updateRows
V10.1 python code
import arcpy, sys, os
inputTable = arcpy.GetParameterAsText(0)
readField = arcpy.GetParameterAsText(1)
writeField = arcpy.GetParameterAsText(2)
valueList = []
searchRows = arcpy.da.SearchCursor(inputTable)
while searchRow:
    searchRowValue = searchRow.getValue(readField)
    else:
del seachRow
del searchRows
valueList.sort
if  listLength == 0:
else:
updateRows = arcpy.da.UpdateCursor(inputTable)
while updateRow:
del updateRow
del updateRows
DouglasSands
One more thing, you can replace all of this:
valueList.sort
if  listLength == 0:
else:
With:
medianValue = numpy.median(valueList)
By importing numpy at the beginning of your script. The list also does not need to be sorted and you don't have to put in the logic to handle all of the list length issues. If there is an empty list, numpy will return "nan" (not a number). After calculating this, you can use numpy.isnan() to test and exit:
if numpy.isnan(medianValue):
    sys.exit()
DouglasSands
With arcpy.da, search cursors work a bit differently. You need to explicitly say which fields you want to be in your search cursor (arcpy.da.SearchCursor Help). This must be a list of fields, even though in your case you have just one. You then access the values in the row in the same way that you would pull items from a list.
So for your example, you would want something like this with the search cursor:
with arcpy.da.SearchCursor(inputTable, [readField]) as searchRows:
    for searchRow in searchRows:
        if searchRow[0] != None:
            valueList.append(searchRow[0])
        del searchRow
del searchRows
The update cursor would work similarly (arcpy.da.UpdateCursor Help😞
with arcpy.da.UpdateCursor(inputTable, [writeField]) as updateRows:
    for row in updateRows:
        row[0] = medianValue
        updateRows.updateRow(row)
        del row
del updateRows
Because you are iterating over lists, this should also run faster than the old cursors did.
T__WayneWhitley
Honored Contributor
Yes, just like the error says, on line 8... in the da.searchcursor, you have to enter a 2nd required parameter for fields.
I'd recommend you try the da cursor, but if you just wanted to make this run for now...there's still the 'regular' cursor, probably for backward compatiblity support, just take out the .da:
searchRows = arcpy.SearchCursor(inputTable)
by Anonymous User
Not applicable
I wrote a tool to do this a while ago, this has always worked for me:
Written By Caleb Mackey
4/17/2013
Calculates Median Statistics
import arcpy, os, sys, traceback
# env settings
arcpy.env.overwriteOutput = True
arcpy.env.qualifiedFieldNames = False
def GetMedian(in_list):
    sorted_list = sorted(in_list)
    median = int(round(len(sorted_list) / 2))
    if len(sorted_list)%2==0:
        med_val = float(sorted_list[median-1]
                        + sorted_list[median]) / 2
    else:
        med_val = sorted_list[median]
    return med_val
def GetMedianValues(source_fc, new_table, case_field, value_field):
    ''' Generates a table with Median Values, summarized by case_field. If the
        goal is to get the median for the entire table, use a case field that has
        the same value for all records.
        source_fc - input feature class to compute median statistics for
        new_table - output table
        case_field - similar to dissolve field, computes stats based on unique values in this field
        value_field - field that contains the actual values for statistics; must be numeric
    # Get unique value list for query
    print 'starting cursor'
    with arcpy.da.SearchCursor(source_fc, [case_field]) as rows:
        un_vals = list(set(r[0] for r in rows))
    lyr = arcpy.MakeFeatureLayer_management(source_fc,'source_layer')
    values = {}
    # Get Median UseValue for each station name
    for st in un_vals:
        query = '"{0}" = \'{1}\''.format(case_field, st)
        arcpy.SelectLayerByAttribute_management(lyr, 'NEW_SELECTION', query)
        use_vals = []
        with arcpy.da.SearchCursor(lyr, [value_field]) as rows:
            for row in rows:
                if row[0] != None:
                    use_vals.append(row[0])
        if len(use_vals) > 0:
            median = GetMedian(use_vals)
            values[st] = [median, len(use_vals)]
    # Create new Summary Statistics table with median
    if arcpy.Exists(new_table):
        arcpy.Delete_management(new_table)
    arcpy.CreateTable_management(os.path.split(new_table)[0],os.path.basename(new_table))
    # Get field names and types
    for field in arcpy.ListFields(source_fc):
        if field.name in [case_field, value_field]:
            ftype = field.type
            name = field.name
            length = field.length
            pres = field.precision
            scale = field.scale
            if name == value_field:
                if new_table.endswith('.dbf'):
                    name = 'MED_' + value_field[:6]
                else:
                value_field2 = name
            arcpy.AddField_management(new_table,name,ftype,pres,scale,length)
    # Add frequency field
    arcpy.AddField_management(new_table,'FREQUENCY','LONG')
    # Insert rows
    with arcpy.da.InsertCursor(new_table, [case_field, value_field2, 'FREQUENCY']) as rows:
        for k,v in sorted(values.iteritems()):
            rows.insertRow((k, v[0], v[1]))
    # report results
    print 'Created %s' %os.path.basename(new_table)
    arcpy.AddMessage('Created %s' %os.path.basename(new_table))
    # .dbf's are automatically given a 'Field1' field...Clean this up
    try:
            arcpy.DeleteField_management(new_table, 'Field1')
    except:
        pass
    print 'Done'
if __name__ == '__main__':
##    # testing
##    source_fc = r'C:\Testing\Test.gdb\CSR_by_TWP'
####    new_table = r'C:\Testing\Test.gdb\Median_CSR' #gdb test
##    new_table = r'C:\Testing\Median_CSR.dbf'  #dbf test
##    case_field = 'NAME'
##    value_field = 'AVE_CSR'
    # Script tool params
    source_fc = arcpy.GetParameterAsText(0)
    new_table = arcpy.GetParameterAsText(1)
    case_field = arcpy.GetParameterAsText(2)
    value_field = arcpy.GetParameterAsText(3)
Hope this helps
EDIT: I should mention this is a 10.1 + version.
KatjaKrivoruchko
Thanks for posting this, very helpful! I have updated it to Python 3.x, which is what ArcGIS Pro ships with:
4/17/2013
Updated to Python 3.x (ArcGIS Pro 1.0) by Katja Krivoruchko
4/16/2015
# env settings
    else:
    return med_val
    values = {}
    for st in un_vals:
        use_vals = []
            for row in rows:
                if row[0] != None:
            ftype = field.type
            name = field.name
            scale = field.scale
                else:
                value_field2 = name
    # Insert rows
        for k,v in sorted(values.items()):
    # report results
    print ('Created %s' %os.path.basename(new_table)  )
    try:
    except:
        pass
    #print 'Done'
DanHoffman1
Thank you Caleb...worked like a charm!  I naively thought that 'median' was just going to be a simple calculation function in the Field Calculator...thank god for your script!
by Anonymous User
Not applicable
No problem, glad to see this is still getting used!
DouglasSands
valueList.sort
if  listLength == 0:
else:
With:
    sys.exit()
DanPatterson_Retired
Once numeric values are obtained from a field, via whatever means, medians are relatively easy to determine using numpy even if the field contains NaN's
>>> import numpy as np
>>> a = np.array([1,2,np.NaN,3.,4,np.NaN],dtype='float64')
>>> np.median(a)
3.5
>>> np.nanmedian(a)
2.5
SamanehHejazi1
that's why I love numpy and panda
