parameter in arcpy
3525
04-10-2016 10:18 PM
jayasudha
I am trying to create python script tool which takes parameter.
x = arcpy.GetParameterAsText(0)
arcpy.MakeFeatureLayer_management("C:/test.gdb/cities","cities_lyr", """ "STATE_NAME" = 'Idaho' """)
How to pass value of x variable for STATE_NAME instead of constant value 'Idaho' ?
Tags (1)
AndrewKeith3
arcpy.MakeFeatureLayer_management("C:/test.gdb/cities","cities_lyr", """ "STATE_NAME" = '{0}' """.format(x))
DanPatterson_Retired
state_name = arcpy.GetParameterAsText(1) # just get the sql query formulated correctly or define this parameter as an SQL in the tool in the parameter type
AndrewKeith3
DavidWasserman
I would also consider using the "Add Field Delimiters" function. It makes sure you have appropriate delimiters for your SQL queries.
AddFieldDelimiters—ArcPy Functions | ArcGIS for Desktop
Example:
GeodesignToolkit-GIS-CityEngine-Integration-Tools/SplitFeaturebyAttribute.py at master · Holisticnat...
def constructSQLEqualityQuery(fieldName, value, dataSource):
    # Creates a workspace sensitive equality query to be used in arcpy.
    return "{0} = '{1}'".format(arcpy.AddFieldDelimiters(dataSource, fieldName), str(value))
David Wasserman, AICP
jayasudha
Thanks to all for your suggestions.
