Parameter B selection of features based on Parameter A Geodatabase - Python Toolbox
1912
10-20-2023 02:08 PM
Jake_S
by Esri Contributor
Hey folks,
New to python toolboxes.
What I'm looking to do
parameter A -  user defined Geodatabase
parameter B -  list of features in parameter A or in datasets within parameter A the user can select one or more
Then the execute code does thing to those selected features only
I'm a bit stumped is this possible.
Current code
# -*- coding: utf-8 -*-
import arcpy
class Toolbox(object):
    def __init__(self):
        """Define the toolbox (the name of the toolbox is the name of the
        .pyt file)."""
        self.label = "Toolbox"
        self.alias = "toolbox"
        # List of tool classes associated with this toolbox
        self.tools = [Tool]
class Tool(object):
    def __init__(self):
        """Define the tool (tool name is the name of the class)."""
        self.label = "Parcel Migration Data Conversion"
        self.description = ""
        self.canRunInBackground = False
    def getParameterInfo(self):
        """Define parameter definitions"""
        # Create a geodatabase parameter
        geodatabase = arcpy.Parameter(
            displayName="Input Geodatabase",
            name="geodatabase",
            datatype="DEWorkspace",
            parameterType="Required",
            direction="Input")
        # Create a feature class parameter
        feature_classes = arcpy.Parameter(
            displayName="Feature Classes",
            name="feature_classes",
            datatype="DEFeatureClass",
            direction="Input",
            multiValue=True)
        #feature_classes.filter.list = []
        #feature_classes.parameterDependencies = [geodatabase.name]
        # Add the parameters to a parameter list
        params = [geodatabase, feature_classes]
        return params
    def isLicensed(self):
        """Set whether tool is licensed to execute."""
        return True
    def updateParameters(self, parameters):
        """Modify the values and properties of parameters before internal
        validation is performed.  This method is called whenever a parameter
        has been changed."""
        gdb = parameters[0]
        fclist = []
        for fc in arcpy.ListFeatureClasses(feature_dataset=gdb):
            fclist.append(fc)
        parameters[1].filter.list = fclist
        return
    def updateMessages(self, parameters):
        """Modify the messages created by internal validation for each tool
        parameter.  This method is called after internal validation."""
        return
    def execute(self, parameters, messages):
        """The source code of the tool."""
        ## do stuff code goes here
        "params[1] = list of features"
        return
    def postExecute(self, parameters):
        """This method takes place after outputs are processed and
        added to the display."""
        return
Current script toolbox and geodatbase
Thanks in advance!
BlakeTerhune
I think you need to define parameter B as GPValueTable and populate the ValueList filter with a list of feature class names.
Defining parameters in a Python toolbox—ArcGIS Pro | Documentation
StaticK
You have your gdb set to the feature dataset parameter in the List Featureclass which I think will return in an empty list.  You need to iterate through the gdb, by setting the arcpy.env.workspace to the gdb and use ListDatasets() with ListFeatureClasses to get them:
arcpy.env.workspace = gdb
if self.params[0].altered:
    _tmparray = []
    for ds in [ds for ds in arcpy.ListDatasets(feature_type='feature') if ds is not None and ds != '']:
            for fc in [fc for fc in arcpy.ListFeatureClasses(feature_dataset=ds) if fc not in fcExclude]:
                    # append featureclass string to the fc list
                    _tmparray.append(fc)
    fcFilter = self.params[1].filter
    fcFilter.list = _tmparray
 Adding the .altered flag to that param will execute the list filter each time a new gdb is selected.
