PackageLayer_management() - Access Use and Constraints
2076
10-13-2014 08:26 AM
JohnDye
When you create a layer package manually through the ArcMap Table of Contents, there is a textbox labeled 'Access Use and Constraints'.
I have a few questions on this little...property (I guess that's what it is)
First, what is the actual intent of this property?
Is it for me to enter things like classifications (ie. Public, Confidential, Proprietary, Secret, Top Secret, etc.)?
If so, what's the point as there doesn't seem to be a way to interrogate it or even set it through arcpy?
Additionally, that property also does not seem to become a property on the Layerfile or Featureclass packaged into the LPK when they are extracted, so I mean really...I don't know what to do with it.
Secondly, why is it unique to LPKs or more correctly Packages?
I mean, an LPK is just essentially a zipped Geodatabase replica (or shapefile...and shame on you if that's the case) and Layerfile. Admittedly, it's a little more than that because if you change the extension to .zip, you can't extract it so there's a little more going on under the hood there, but conceptually that's what we're dealing with.
What's more, when you extract an LPK, you get the dataset and a layerfile referencing the dataset in your assembly cache and the layerfile is what gets added to your MXD but since Layerfiles nor Feature Classes have no Access Use and Constraints property there's no place for that property to be assigned. So...poof? It goes into the abyss? I'm just really confused over the whole thing.
Summary is another property which Layerfiles and Feature Classes do not have, but I'm able to rationalize that property a bit more because Layer Packages can contain multiple datasets and layers. Therefore, a summary is useful in that it can provide information about the contents...so could the description as well...darn it, confused again...
JakeSkinner
Esri Esteemed Contributor
Hi John,
The Access Use and Constraints option is applicable when you are uploading the Layer Package to ArcGIS Online.  When using the PackageLayer tool, unfortunately there is not an option to create the layer package and upload it to ArcGIS Online as there is when doing this through Desktop.
The use of this parameter is optional text describing the restrictions and legal prerequisites for accessing and using the service/data. For example, you could specify a message stating, "For internal use only. Do not distribute."
Below is an example of one of ESRI's free basemaps accessed through ArcGIS Online.  You will notice the 'Access Use and Constraints' option.
JohnDye
Thanks Jake,
That makes a lot more sense. While I know its not a required entry for the PackageLayer tool to execute, it would be useful to be able to set that property through a parameter on the tool since that property can't be ported from a Layerfile or Feature Layer into the package when you're creating it since those input datatypes don't have that property.
Was the idea behind not including that property in the GP tool to create a behavior where Access and Use Constraints is would always be null unless someone took the time to package and upload the LPKs 1-by-1 through the GUI?
JakeSkinner
I believe this functionality should be included with the Share Package tool.  You could have a workflow/model/script to create a layer package and then upload to ArcGIS Online using the Share Package tool (specifying the Access and Constraints option).  If you have ideas we encourage users to post them on the ArcGIS Ideas page:
Esri Arcgis Ideas | Ideas Submission Portal
